Pete's (Now Nate's) 2003 Denali Budget Build thread
05Single
afraid of the dark
she's always trying to steal the spotlight
More like the spotlight is always looking for her !!
#manydrools #muchfapping
adventurenali92
Big Bear Lake, ca
You can still do it nate....get that +/- going in that traction control, i have faith in you @HiHoeSilver
I’d love to figure out how to make the plus minus buttons work to control traction control. Lol. That’s be awesome! Then I could 86 the little round button on the right side of the dash and totally redo that little cubby and make it into something useful! Lol.
Sevenevez
Sevenevez
Arizona
or to control your helper bags. makes sense right by the tow button
HiHoeSilver
Away!
Chicago
You just need to match the two same-colored wires from your original shifter to the new shifter. Orange and white if I remember right. As for the + - buttons, they have resistors built into the shifter that make them worthless unless you can figure out how to remove those.
Where there a will....
Kingfish585
Here's the Suburban i sold. It only had 53,000 original miles. Which is why i got 6000 for it.
It's amazing you can take this little stack of paper and turn it into a vehicle that was once worth $50,000 :)
Here's a few of my older OBS builds from the past
2000 Tahoe Limited
1997 fast bagged Silverado
1995 GMC Sierra
HAHA feeling like a real big baller with stacks! I bought my denali with a stack too. Love your collection of rides over the years.
Kingfish585
I think your 06 suburban may be the only 06 out there under 60k original miles. my 05 denali had 185k when i bought it last june and its pushing 215k today.
Sevenevez
Sevenevez
Arizona
that thing was problematic though. something broke or went bad almost everytime it was driven. i had it for like a year and put plenty of money into it. i was happy to let it go
Sevenevez
Sevenevez
Arizona
My wiper washer has never squirted. Bought a new pump for like $7 on eBay
To put it in i had to remove my battery.. then remove the battery tray (7 bolts - 10mm) and one bolt holding the top of the washer tank
If you have oversized wheels you will need to take your wheel off. Then the clips that hold the fender plastic. Then one more 10mm holding the right bottom of the washer tank.
(i also wanted to check the rubbing/squeal noise from my brakes so it worked out fine. My backing plate was pretty much resting on the rotor. Lightly bent it away to cure my noise.)
unplug the wiring from your front pump (blue connector on the pump closest to you). pull its hose off. Pull the pump off and swap em!
note: mine was full of fluid so i used a catch bucket as you see.
we have Squirt! all fixed.
yea yeah, i live in Arizona and it rarely rains. But long trips with bugs on the window and no fluid to help the wipers get em off was annoying. (it actually rained lightly twice this week)
squeak gone. washer pumpin. thumbs up!
Sevenevez
Sevenevez
Arizona
Nice little write-up for those of us who might have to do this one day. Luckily mine still works so far but it is 15 years old.
yeah, if it wasn't hidden under and behind it woulda been a fast 5min job. Probably took me about 30-45min. The rear window pump looked the same. i bet you could swap em.
varminpoolteam
