Panhard hitting frame
02chevyhoe
I have an 02 tahoe with Tony's 3/5.5 kit I've ran for a few month and it rides great till a hit a bump. My panhard bottoms out in my frame has anyone had this issue and found a fix? Tony recommends getting an adjustable one or at least check my bushing wich ill do once I have money
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yours is the first ive seen this. Check the panhard bar make sure the bushings arent shot.
02chevyhoe
On other tahoes does the panhard even come close to the frame or is mine just aligned weird
Alex33
Mine doesn't and it's pretty low. The only issue I have is the bracket hitting the rear sway bar because the reloc kit doesn't move it far enough.
azchrome
^ i have this issue as well. moved sway bar with kit but still hits bracket. anyone know how to fix this?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
can you guys post the wayou have the bar moutned up?? usaully i do the links on inside of drivers and outside of passengers with movint it over 1.25 inches and clears the bracket fine.
azchrome
do i just need to flip the driver side link around? and it may give me enough clearance.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
What sway bar links are those?
I want some new ones for my ride... thanks!
he got the kit off from me. Includes trailing arm relocators and the swaybar endlink relocators. $165 shipped
as for the bar set up it goes on the inside of the drivers link and outside of pass link. If yoru using the right link should clear that mount no problem
throwaway5262
