Cleanliness is next to Godliness. Get some paper shop towels at the parts store or a couple packages of the red cloth shop towels. Look inside each port with a bright light to see how it all looks. Then CAREFULLY use a wet towel soaked in parts cleaner or brake cleaner and reach slowly in the ports and pull out any loose debris. Then CAREFULLY stuff the towels in the ports and clean up in that valley and all around the ports. I like to use a single edge razor blade around the ports, in a blade holder with a tilt to it. Pristine cleanliness at those ports and the intake makes for a nice mating when going back together. I like Fel Pro gaskets/seals but Genuine GM is great too, or AC Delco. While apart, I would do the harness pigtail for the sensor as well and of course anything related that you took apart. I love spending other people's money.
Sensor at back next to oil sensor? Is there an updated throttle body harness as well?
