P0455 Error Code Question
GONO2
I am getting a P0455 error code on my 2003 Yukon. Gas cap has been replaced and code keeps coming back. The system is holding pressure as it relieves itself when I remove the gas cap. Code does not come up unless I let the tank get under 1/2 full. If I keep the tank well above 1/2, I do not get the code.
Any suggestions?
Thanks!!!
afpj
Is it an OEM gas cap? I had similar issues with a nonOEM locking cap...switched to OEM (yeah, cost alot more) but no more CEL.
04Hoe
A code p0455 most likely means one or more of the following has happened:
* A loose or improperly affixed gas cap
* A non-conforming gas cap (i.e. not factory/original brand)
* Other leak or damaged piece in EVAP system
With a p0455, the most common repair is to:
* Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
* Otherwise, replace the gas cap, and/or
* Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary
G
GONO2
does anyone know the part number for the OEM gas cap?
Thanks
AdrienR
