Overheating after New Intake gaskets..?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I want tranny temp, water temp, coolant pressure(yeah you read that right) power steering temp, tranny line pressure, fuel pressure, vacuum, A/F ratio for each bank, Volt and ammeter for 2 each batteries and for alternator, oil temp, indoor /outdoor temp.
---------- Post added at 03:24 PM ---------- Previous post was at 03:21 PM ----------
for now just using a Scangauge II Which I understand can be piggybacked with each other but you can not add inputs to it. Reads directly of the diag connector. Thought about stacking a few together. But also limited on what is available from pcm.
---------- Post added at 03:28 PM ---------- Previous post was at 03:24 PM ----------
Although all the gauges in autometer form would be good too. The issue I have with it is I need some of the faceplate names changed like for coolant pressure or PS temp, trans press..etc.
B
BattelWagun
Chi-Town USA
Yeah I know exactly what you mean, I wish I had a place to mount a dozen gauges because frankly, If I had an intake vacuum, water pressure, and a good water temp gauge I guarantee you I would've seen those gaskets going way sooner... I've been looking across the interwebz and I found banks makes a nice 3 gauge pillar pod, and I found a nice 3 gauge dash pod (not hoe specific, but i think it would work...). And I'll tell ya, I'm gettin' idears here :shocked:
I want to fix the coolant gauge in my cluster so I dont need to waste space with that, then:
1)vacuum(this one will satisfy my immaturity), coolant press, and EGT/ fuel trim on dash
2)Oil temp, tranny temp, and fuel pressure maybe?
thats just A LOT of work haha
However, I can COMPLETELY justify all of this because abnormalities in all of these gauge readings would tell me quite a bit about what is wrong with her, should something go wrong...
SunlitComet
OBS Jedi-Do Good
That is the idea. A little chime-for a warning here or there. If several go at once- maybe a beeping alarm. Engine stalls while at high vehicle speed-a nice big Klaxon alarm and blinking red "warning" light.
I could make an aircraft type master-alarm circuit. That would be cool. But that probably means changing the instrumentation system to a data acquisition type system. Could easily go past a grand in cost. I don't have the money too. I got to get this monster fixed so I can work again.
B
BattelWagun
Chi-Town USA
Yeah getting her running would definitely be your best choice right now! haha
but I think I just may go that route, with many gauges... many, many gauges... :)
then I shall rename it the spaceship!
Am I really really gonna have to pay upwards of 50 bucks for a pillar pod?! comeon man...
B
BattelWagun
Chi-Town USA
Alright I guess I'll just have to fork up the dough then... I found one for about 30 bucks from a company called 'GlowShift' but seeing as it's $20-$30 cheaper than everyone else, I'm kinda worried about quality issues. I dont want a piece of crap on my a-pillar in front of my face haha.
as for wiring, I would just use an add a circiut and wire the gauges lights into the dimmer circiut, right?
SunlitComet
OBS Jedi-Do Good
one for ignition power on, one wire for illumination, ground and whatever the sensor uses. A good circuit in the truck can handle each type of wire for three gauges.
---------- Post added at 09:34 AM ---------- Previous post was at 09:33 AM ----------
need a recommendation for the power and lighting circuits?
SunlitComet
OBS Jedi-Do Good
try fuse #4 for ignition on control and #14 for illumination control. would not add more than three gauges on these circuits for now. But you could always add a relayed setup for more later.
B
BattelWagun
Chi-Town USA
Okay thats fine then, I want to definitely put in a triple gauge A-pillar with vacuum, trans temp, and oil temp or water press. I think the vacuum gauge is mecanincal, but I'd still have to wire up the light for it.
B
BattelWagun
Chi-Town USA
Eeeexcelenttt *mr burns voice*
Well I should be getting a little extra $$$ from a brake Job I'm doing this week, then I'll order everything up and install (possibly make a how to for each gauge too...)
crows feet
Elberton Georgia
your intake gaskets are on wrong..take it from me replaced every thing thermo water pump new hoses new raditor because i had so much trust in guy that put them on he just made a big bo bo get another set from dealer not much diff in price use your vin make sure got right ones will work,,,,,or they are on backwards or upside down read paper work from your pack save your self time and worry that is the problem
retorq
Kingman AZ
Did you look at the pics and read what others posted?? There is no "backwards" on Vortecs and upside down would just be silly ...
vsaravia
