Ordering 4L80E + Torque Converter
blackcoffee
O.G. Black.
I'm ordering my 4L80E from Monster Transmissions tomorrow.
I'm going with the Mega Monster Heavy Duty 4L80E.
[Part# MG4-4L80E]
$1,995.00
I'll be ordering a Torque Converter as well, from Yank.
I need to figure out what kind of stall I'll need.
This is my Daily Driver, my Towing Vehicle, My mudding Vehicle, And my hauling ass Vehicle.
What would be the best all around Stall?
Also, what else will need? I know I need to get some transmission fluid.
I'll need to modify the cross member.
I also need to get a nice transmission cooler, I really don't want to ruin this thing I'm putting alot of money into this.
Please post, and help me make the right decision.
95TwinTT
Minnesota
You should not have to modify the cross member. Look at your frame, there should be another set of bolt holes south of the current location. Just slide the cross member to the next set of holes. The mount itself, should fit the new tranny.
Don’t get carried away with a external cooler. The stock cooling system in your radiator is more than enough.
You will need a new dip stick and tube, the old one won’t reach.
Since the 4L80 will be able to operate at normal pressures for your application, there is no way heat will ever be an issue. Plus the synthetic oil is nice, but it’s main benefit is holding viscosity when very hot. In normal applications, standard ATF is more than good enough.
As far as stall speed goes, for your situation I would not go over 3200. A lot of the higher speed TC’s are smaller in diameter. To keep the specs up on the lockup, they add multiple disc’s. I’ve got three in mine.
You are buying a very good transmission, don’t cut corners with the TC, that’s the key to getting the most out of the tranny. Get some advice from the tranny builder on what TC they would recommend.
Good luck, sounds like a fun project….. :)
blackcoffee
blackcoffee
O.G. Black.
Oh alright, I always thought you had to modify the cross member for the 80 to fit. Atleast that's one thing I won't have to worry about.
You really don't think I'll need an external cooler, not even a small one?
I won't cut corners with the TC, thats why I plan to purchase a "Yank" I've read a lot of 80E swap builds and the best comments for TC's seem to be from the YANK TC's.
I'll call Monster Transmissions tomorrow.
Hopefully I'll be able to purchase both the transmission and the TC tomorrow.
I'm just going to get everything ordered I need.
Next to find will be the LQ4 6.0L. But I'm gonna get this squared away first.
---------- Post added at 10:35 PM ---------- Previous post was at 10:30 PM ----------
After looking at Yank's website for awhile,
I think the YANK TRUCK THRUSTER 2600 will suffice.
278mm, 2600 stall, 2.10 STR
---------- Post added at 10:36 PM ---------- Previous post was at 10:35 PM ----------
I'll also be doing a Lokar Automatic Floor shifter.
Is this in any way a bad idea?
I've always wanted one.
hehehe
---------- Post added at 10:38 PM ---------- Previous post was at 10:36 PM ----------
Never mind, I won't be able to go with that TC it is not intended for use with the 4L80.
I'd more likely go with the
YANK TRUCK THRUSTER 2600HD 4L80E
300mm, 2600 stall, 2.0 STR | This converter is a significant step up from stock, but will maintain all the towing capacity intended for this heavy duty class of Trucks.
But, its $900.... Is that rediculous?
---------- Post added at 11:20 PM ---------- Previous post was at 10:38 PM ----------
Parts needed to complete the 4L60E to 4L80E transmission swap:
Transmission $2500.00 - $500.00 = $2000.00 (After Refund)
4L80e torque converter $350.00
Transmission Cooler - Not currently needed
80e flex plate – PN:12551367
Flex plate bolts – 12563533
Flex plate spacer – PN:12563532 Advanced Adapters 1-800-350-2223 Ext. 522 Ask for Jim.
Torque converter bolts – local parts store
Lower bell housing – PN:15765723
Lower bell housing bolts – PN:11516328
Lokar Automatic Floor Shifter - $210.00
Lokar LED Boot & Mount - $75.00
80e gear selector cable bracket $?.00
HD truck dipstick tube – PN:15832205
Transmission mount – reuse PN:22201140
Dual Cardinal driveshaft $429.00
Pre ’99 rear end seal – NAPA PN:19273
PCM 80e calibration – Black Bear - $0.00
60e to 80e conversion harness
Transmission Fluid - $150.00
change the input gear in transfer case (NP241)
The factory transmission lines are not going to line up. The front line can be straightened out so that is pushes in to the front trans line connector.
The back line needs to be extended.
Clean the transmission lines, cooler and any external coolers with a can of transmission line cleaner
95TwinTT
Minnesota
A good converter will be in the $1,000 range.
Converters are an art to themselves. There are so many variables. I only trust the guys at Midwest Performance Converters. They make precision converters.
http://midwestconverter.com/SLING.html
Check out the questions they ask for making a custom TC. Might give you some ideas as to what to ask your converter guys.
Just make sure the converter you buy, can handle high rpm’s and has a good “Lock up” clutch system. Many of the high stalls don’t offer lock up.
As far as the floor shifter goes, I think the column shift is fine for 99% of driving. The other 1%, I use a electric paddle shifter when I switch to manual shifting. I have the paddle button next to the edge of the front seat, on the side of the center console. :)
blackcoffee
blackcoffee
O.G. Black.
Picked up the 4L80E yesterday. Got it to the shop today, all went well. 1800-2000 stall torque converter.
Heres the road to monster transmissions in Brooksville florida. Pretty nice place.
95TwinTT
Minnesota
That 1800 to 2000 stall is basically stock. It might not be as responsive as your 4L60e was, seeing as how the 80 has a taller first gear.
Maybe you will get lucky and it will actually spin faster..... :)
blackcoffee
blackcoffee
O.G. Black.
Well I was expecting that, I just went with 1800 - 2000 stall with a lock up because I tow quite a bit.
On to my next question, 95TwinTT. We both have 4wd and 2 doors.
Could you name every part I will need, IN detail.
I know this is asking a lot...
But it would really help, I know I need to change the driveshaft, dipstick, pcm tune, transfer case, wiring harness, flywheel crossmember. Now I'm not positive on these, but this guy I take my truck once in awhile keeps telling me I'm screwed because I'm still gonna need thousands of dollars in parts. I know I might need a few parts but, I'm sure its not going to cost me thousands.
95TwinTT
Minnesota
We used the same transfer case. The input shaft was changed to match the 80.
I had a new drive shaft made for the front and shortened the existing rear drive shaft, changing the front u-joint and spline to match the larger size of the 80.
The cross member is the same as well as the trans mount. It is just slid back to the next set of holes in the frame.
The dip stick and tube was just ordered from a local chev dealer.
I did not keep any record of part numbers, sorry. Electronically, I switched to a separate computer for the trans, with it’s own wiring harness (TCI/TCU). I remember from the schematics, that there are a couple wires different from the 60. The computer and wiring harness I use, has a jumper wire and plug to change back and forth from 4L60 to 4L80. The other changes are made in the software from the laptop computer.
If I remember right, your OBD2. I have to believe that it can be changed over to the 80 with some editing, but the wiring harness from it to the trans, will have to be modified or changed. If you could find a schematic with the “pin outs” of the trans and OBD2, you could probably change the harness you have. The color coded wires make it fairly easy if your into wiring…..
I only use the rear speed sensor and it works fine for speedo and trans control.
My 4x4 is manual, so I just welded an extension on the shift rod to make is fit. The neutral safety switch was the same as for the 60.
That’s about all I can recall about the swap. I hope it helps some.
blackcoffee
blackcoffee
O.G. Black.
Sweet man, well thats not horrible. Now the only things I need to figure out myself is wiring and the whole transfer case thing since I have autotrac. How about the fly wheel do you remember anything?
95TwinTT
Minnesota
Seems to me the flexplate was the same. I know I just replaced mine and the only question was internally balanced or external. They didn't seem to care what transmission it was hooked to.
If you check into it with the transmission people, I think you will find that your transfer case can be modified. They use the same chain and all, just the input shaft and rear seal change. Maybe it's different with the manual, but I remember it not being a big deal.
If you can get the pin out info, I think you could make the changes at the end of the harness that plugs into the ECM. You should not have to mess with both ends of the cable. :)
blackcoffee
blackcoffee
O.G. Black.
Wow man, loads of help here! Thank you so much! We'll have to make a sticky when I'm all done, I'll save all receipts and product numbers.
blackcoffee
blackcoffee
O.G. Black.
I returned the 4L80e, and had a 4L65E SS Mega Monster built instead.
("It is ideal for vehicles powered by 4.8, 5.3, LS1, or 6.0L engines producing up to 650 horsepower with a non-nitrous system using pump gasoline.") =D
I'll be picking it up Thursday. I didn't want to go through with all the swapping that I'd have to do with the 80e. Sorry guys. But I have a question, how many bolts go on the bell housing on a 4L60E, 4 or 5?
---------- Post added at 11:36 PM ---------- Previous post was at 11:03 PM ----------
If anybody knows what I'm talking about. I'd really appreciate an answer, it would help a lot. To me it looks like there are 5. But I cannot be sure without getting it on a lift.
THE-HOE
Pittsburgh Pa
You really should get a tranny cooler, the stock radiator is not good enough like stated above. Especially if you will be mudding / racing. I did not have a tranny cooler on my 96 and installed a tranny temp gauge, I soon learned that while mudding and messing around the fluid temperature was way above what is should be. I installed a cooler and it would stay one consistent temperature.
If you do get one, remember to utilize the stock radiator cooling part of it, then run it to your tranny cooler than back to the tranny. If you go to the cooler first then the radiator there is no point in even having a cooler.
Also, when buying a cooler do not go too large, just look for one that is rated for a vehicle one weight class heavier than you're truck and that will do the trick. Some people put huge ones on, and their fluid stays too cold for too long, resulting in the tranny /converter to not go into "lock up."
blackcoffee
blackcoffee
O.G. Black.
Thanks for the input "The-Hoe" I do plan to run a tranny cooler because I do plan to run it hard at times, and It'll have the floor shifter and I would like to be able to keep it in gear at high rpm's at times and keeping it cool is the factor but keeping it lubricated is also important. But for the time being I'll be running Schaeffer's Supreme synthetic transmission fluid which is tried and true. This is a budget build, and when funds become available they will be put towards the truck. I should get the transmission in next week, monday or tuesday. I really need somebody to answer my question though,
"How many bolts go on the bell housing on a 4L60E, 4 or 5? If anybody knows what I'm talking about, I'd really appreciate an answer, it would help a lot. To me it looks like there are 5. But I cannot be sure without getting it on a lift. "
quickie
there should be 6 2 on each side and 2 on the top of the tranny
so 6 total
blackcoffee
blackcoffee
O.G. Black.
Hummm, maybe I'm asking the wrong thing. I'll have to call monster transmissions and ask more specifically, what they need to know. Were trying to figure out if a 4L65E is gonna mount up to my truck? Anybody know?!
95TwinTT
Minnesota
Is it just me or do you change you mind a lot?
There are six bolts for sure holding the trans to the engine block and sometimes they use a seventh bolt at the very top. The later model 4L80e tranny's had the top position open for the seventh bolt. The older cases are blank at the top.
In other words the seventh bolt is optional. if you get a trans with a bolt hole there, fill it with a bolt. lol
vsaravia
