ordered some Treadwright tires
arctic388
arctic388
got them put on. two of them took a lot of weight to balance. my first impression was they were soft. so i thought they had to little air pressure but when i checked they had 40 in them. i upped that to 46 and it seems to be better now. going from the 245 long trail's these are a lot louder and at least twice as heavy per tire. my speedometer is correct now.
arctic388
arctic388
tread view
arctic388
arctic388
few pics
i googled some pressures for D rated and most what i found said to run 50psi.
Smasal
Southwest, Mo
Those look amazing man. Nice job. And I concur on the 50psi. It will hopefully help with that "heavy" feeling that you talk about. Because you won't be pushing the vehicle as much as rolling.
Ch@d
HotCarl
ID/WA
Those look excellent. I will be needing some new summer tires next year, looking to go to a 285 tho, interested in hearing how these treat ya. BTW we have the exact same paint color schemes on our hoes, first time I have seen a twin of mine.
arctic388
arctic388
had a slow leak and took it to get checked. turns out a patch was already in it and leaking. they put a new patch in and so hopefully wont have any more issues.
arctic388
arctic388
Yep. It was a very small hole the tire shop put it in a big water tub to find leak. When he dismounted tire it was an old patch in it. He buffed it out and put a new patch in. I hope it holds.
Smasal
Southwest, Mo
Man I'm sure that's normal in retreads. Maybe you give treadwright a call just to see what they say? I would
Ch@d
phillydog07
I wouldn't think a patched tire would be normal with retreads. Their website states that they use "gently used" tires. To me, that would logically preclude tires that have been patched.
Sent from my ADR6300 using Tapatalk
Smasal
Southwest, Mo
I agree Philly. Plus I have considered treadwright and read where they brag how the carefully select the walls. How could the tread even be possible? Are you sure you can trust your shop? Maybe you picked nail up somewhere and they were just bs'n ya?? I don't know just seems odd. Let us know on results.
Ch@d
arctic388
arctic388
I know these guys and watched him the whole time. it had a tiny leak right beside a tread block. if it had been molded just a hair different i don't think it would have leaked. when he buffed the old patch out i actually saw some of the moisture from where we dunked it to find the leak ********* exactly in the middle of where the old patch was.
if i did hit something it didn't leave any trace on the tread and the old patch, as far as i could tell didn't have a puncture mark on it. I looked at it pretty good on the stretcher with a very bright light on it. and if i did hit something and it was exactly the center of the old patch i better go check that lottery ticket i bought that day.
arctic388
arctic388
Saturday i ran up on a curb while parking - on purpose - and my front passenger tire got a nice cut all the way around the outer tread block. my bumper had a nice little point sticking right out where it rubbed. i filed that off and plan to grind it some but i had no idea the 265's would rub. the tire is ok. i just wanted to update this to let people know it will rub when its compressed like that.
arctic388
arctic388
Just by looking it looks like it could never rub but think all the stars aligned, I was on a downgrade turned a little so more than normal weight was on that side. I do plan to add a leaf and crank my bars soon. That should help.
dizhai
