oil presure drops
nick8403
i have a 97 tahoe and when i give it gas the oil pressure drops down enough to get the gauge light to come on but then it rises back up after just second and goes back to normal what could be the problem any help would be appreciated
Gzes
the drifting 2dr
Wichita tx
Oil pump is what ut sounds like. But if not then bearings might be toast
SunlitComet
OBS Jedi-Do Good
unknown at this time.
your oil pan and nearby obstructions needs to be removed and needs to be removed. but you should test with a mechanical gauge if possible to avoid unneeded replacements.
N
nick8403
allright i should mention that it just started doing it a couple days ago and at idle it still holds good pressure and if i put it in a gear and hold the brake and give it gas its still good it only drops when i take off from a stop
retorq
Kingman AZ
You have major issues, these are rear sump engines, when you take off from a light the oil should move to the back other pan and cover the pickup ... good luck lol you're gonna need it.
CKendrick
