Oil Pressure Sensor Error - Safe to Drive?
SunnyInCo
Yesterday my check engine light came on and noticed the oil pressure gauge was reading 0. I checked the oil and it's fine. Today I purchased an OBD instrument and confirmed I am receiving one error, P0523/P0521. The reader I purchased off Amazon has 2 sub-codes under the one error.
Is the vehicle safe to drive until I bring it in this weekend?
St. Louis
It should be just a bad sensor. Mine did this last summer.
It never gave me the "low oil pressure, stop engine" warning, just the check engine light with code and a dead gauge.
SunnyInCo
SunnyInCo
No, no noise at all. Runs the same for the 2 miles I drove to get back home last night. Starting in the garage a few minutes ago to use the OBD its also sounds fine.
SunnyInCo
SunnyInCo
Thanks. Sounds exactly the same as my situation.
St. Louis
And when I cleared the codes just to see if the same codes came back, the gauge would peg all the way to like 80psi and stay there.
My code was something like oil pressure sensor voltage out of range
BadDaddy2003
