Oil Pressure below 40 at idle
tml4life
NorCal
Just noticed this morning while idle at a light that my oil pressure was below 40, more like 38, should I be concerned?
ScottL4619
Columbus, OH
Nothing to be concerned about. When warm and at idle, mine is even lower than that. At full throttle, it almost hits 80. I think synthetic oil also makes a difference as it flows a little easier, thus reducing pressure in the system.
Schwab
Nebraska
Rule of thumb is 10psi oil pressure for every 1000 rpm ;)
Also, Buick used to have an oil pressure problem with one of their engines (can't recall which one for sure) back in the 50's or 60's where pressure would drop to 5 psi at idle, but would be at 40 psi at cruising speed. Funny enough though, they found that at idle, 5 psi of pressure was more than enough to create the clearance needed between bearing surfaces to keep the engine running well and without any abnormal wear.
worleytrev93
