Oil LEAK !
ftwflh
Crossville,IL
Well after having to oil cooler lines replaced I have put a couple hundred miles on it and oil is dripping out of the bell housing. Looks like another trip to the shop. Hope it isnt the rear main seal but it has to be fixed. The shop did put dye in last time so maybe it will show up where the leak is. Any input welcome.
j91z28d1
most drip a bit for years and it doesn't hurt anything but if you really need it it to be dry. you'll end up needing oil pan gasket, rear main seal plate gasket and real main seal.
budget accordingly. gm just didn't use gaskets that hold up to oil for life. why? I don't know.
Charlie21ny
