oil catch can
95escahoe
I've got a 160k mile 6.0 Escalade runs great figured a catch can might be a great addition which ones does anyone use?
95escahoe
95escahoe
Do you have an issue with oil in your intake?
When I cleaned the TB it wasn't too dirty I got a slight oil pan leak I'm using a lil under 1/4 of a quart per 3k miles the stock PCV system on these trucks isn't the best so figured this might be something good to do many do on these generation trucks
pnwdan
Cunning linguist
Arlington, WA
Oh I see. I know that sometimes some vehicles need them but I hadn't heard of anyone using them on these. When I pulled my engine at 169k I didn't see much inside the intake.
95escahoe
95escahoe
Some of these trucks had a replaceable PCV valve the latter ones like mine it's all built in the valve cover (which I think is why the PCV system on these trucks suck) only way to replace it is replace the valve cover so due to that this would help with that if you were having any kinda issues
zzyzx
I have a '13 Tahoe with 75000 miles with a new catch can installed. After a a couple thousand miles I drained about 2 tablespoons of muck, water and oil mix. Not sure what damage it would be doing, but it felt good not having that circulating through the engine. I think it's due to all these short trips my wife takes which is a killer. Also, from what I've read it's more of an issue if you have AFM.
I got one from www.catchcans.com and after my last oil change ( with a new PCV valve installed previously) I got a few tablespoons of oil out of it. I was surprised.
kwOH
Banned
I probably need 2 of these.
Sent from iPhone 7 plus using Tapatalk Pro
2002DenaliXL
As stated above, the PCV system is great for oiling up the intake manifold. When you get time, remove your throttle body and look into the intake with a flash light. You will see the inside has a film of oil all over it. I can post up a picture of my heads (lq4 with 159,*** miles before it died from lifter failure) that I took off that after cleaning in the parts washer, is still covered in build up. This PCV system is used to pass emissions and reduce carbon output.
This thin film of crap from the PCV system leads to what is called coking up of the intake runners on the intake and heads. With the new direct injection motors, this will be much worse as the there is no fuel washing the runner down as it goes into the cylinder.
The build up of oil and crap via the PCV system leads to restrictions and lack of power. I swapped to the LS6 valley cover which is orifice based, doing away with the driver's side valve cover port. Also my motor is naturally aspirated as I don't have boost.
pnwdan
Cunning linguist
Arlington, WA
I understand this. The only reason I was surprised was that when I replaced my lq4 at 170k I had zero valve coking or any signs of pcv problems. One of our other cars is direct injected and boosted and I keep it cleaned out regularly but have been looking into a catch can for it.
rv8pilot
ABQ, NM
I pulled the intake manifold on my '01 Yuk and couldn't believe the amount of black crap coating the entire inside. It had about 235,000 miles on it but even so it was substantial. Not wanting to spend the bucks for a nice machined aluminum can I used an old Sears airline oil/water separator I had lying around. It has a clear plastic bowl, probably polycarbonate to handle the pressure of an air system and I was concerned it might be affected by the heat as it is mounted to the back of the little red plastic battery cable box above the exhaust manifold. After a 600 mile trip this summer in Florida heat at 80 mph I saw no signs of thermal stress. It collects a fair amount of oil as indicated elsewhere in this thread but I have not seen any water yet. I have not inspected the inside of the intake manifold but its clearly removing oil. After couple of thousand miles I probably have drained a couple of ounces.
ZaZaZazzels
