New VCIM for Bluetooth = Onstar RemoteLink?
NathanJax
Vacation Nathan
Jax, Fl
For the 2010-2012 Tahoe and Yukon, you have the option of the Onstar RemoteLink app to start the car and vehicle diagnostics. So I'm reading this thread http://tahoeyukonforum.com/forum/showthread.php?t=29114 and I have a question for those of you who have done it, who also kept OnStar. Are you able to use the app?
I figured if I have the OnStar VCIM from a 2010-2012 Yukon/Tahoe, you should be able to...
So for those who have swapped VCIM's for Bluetooth, and been able to keep OnStar from customer serivce, has anyone tried RemoteLink?
mattah
Austin, TX/Temple, Tx
There is a member on here that had a VCIM from like a traverse or something and he could still use the onstar app. Just onstar saw his car as a traverse instead of what it really is.
I want to do this mod down the road aswell!
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
bump
ryanls1
I did the swap to my 08 tahoe using a vcim from a 2010 traverse and everything including the onstar remote app is fully functional. Onstar just thinks i have a traverse.
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
Sweet. Thanks for the reply!
foxracingfreak
Did you have to tell onstar a different vin #? Or they just saw it was a traverse when you called them up? Any part numbers for this? Thanks
Fitz08
IL
You shouldn't need to tell them the vin from the donor vehicle, they should see it as soon as you call in. And I'm not 100% sure but I think the vcim changed in 2012 along with the factory radio, so all the plugs are different. Just a heads up as I don't think they will work. And the part number I used is 20829984
foxracingfreak
I see there are brand new ones on eBay. If I were to buy a brand new one does it have to be flashes by a dealer or is it good to go right out of the package?
Fitz08
IL
The only ones I've seen on ebay are ones for 2012, and as far as I know they will not work on 07-11 as they have different plugs. If you did find a brand new never installed vcim, then yes I'm pretty sure it would need to be programed by a dealer as it would have no info in it.
foxracingfreak
Oh ok yeah I guess they were 2012. Does the dealer give ya any hassle to flash a vcim that's not the correct one for that certain vehicle?
mtcrumb
Sarasota, Florida
Just a heads up for those of you looking for a VCIM. The one from 2012 will not work in your 2007 to 2011 chevy/GMC. The 2012 VCIM is the newest Gen 9.3 and the plugs are different. Here is a cut and paste from the guy on Ebay selling the 2012.
Due to design changes this module may not work on model years prior to 2012. Bluetooth functionality is a plug and play feature and will work once properly installed and paired with a compatible phone
foxracingfreak
I found one at Schram Auto parts. I emailed them because they didn't have one listed on their site. He said he had one and would get it shipped out this week.
veteran111
