New noise from the nali
Tribalbreak
WARminster PA
so it a squeek... its only at low speed when the gas is applied... it gets faster squeek squeek fast and faster as the truck goes faster then it stops at a higher speed... sounds to fast for breaks or wheel bearings... maybe something with the axle or driveshaft? ujoints maybe? any ideas?
T
Tribalbreak
WARminster PA
it doesn't make a noise when i don't have my foot on the gas... so if the brake was applied no noise. but if i am just coasting it doesn't make the noise either.
Modded
That Guy
Yeah I would think belts and/or pulleys would be the issue since its a squeak??
Rivieraracing
So is the noise engine related (would it squeel if you were in neutral parked and stepped on the gas) or do you have to be moving?
T
Tribalbreak
WARminster PA
does not make any noise when in neutral or park... so i ruled out engine related... its hard to pin point the sound in the truck... i thought maybe u-joints so i filled the rear shaft one via the zurk fittings but the fronts don't have them...
jman901
check both of the U-joints, mine made the same exact noise when the front one started to go
TunasTwins
2005 Tahoe LS
Atlanta
Is the trans mount in good shape? Could be effecting the drive line angles if its on its way out
03YukonNH
Manchester, NH
I agree. I had a similiar noise (if not the same) on my 03 Yukon. It sounded like a wheel bearing or the parking brake assembly came apart and was dragging. It ended up being the rear u-joint. It was dry as hell and looked original. Truck has 194,000 miles on it so I think it was due.
AdrienR
