New moog stuff info
slipping
Rosamond, CA
I want to get all me ball joints, tie rods end links and u joints. If I do everything what all am I looking to do, Moog best for all? And maybe some part numbers? Thanks!
Gzes
the drifting 2dr
Wichita tx
Ball joints are gonna be fun! Not.... I would get all the stuff and let a shop do it bro. Ball joints are upper and lower and should be around $40 a popish. Tie rods and misc arent tok bad niether. I would also check the bishings and replace them because yea we have old ass trucks and the bushings go bad
Danzigman
Galveston, TX
I have had good luck out of PST suspension kits on my muscle cars, they make stuff for our trucks you may give them a try.
slipping
slipping
Rosamond, CA
moog part numbers:
upper joint K6292
lower joint K6445
inner rod ES2837RL
outer rod ES2836RL
Very cool sir, thanks as always! How about the u joints on the drive shaft. I looked at amazon had several AC delco and rock auto had a long list. Are the all the same less lubed/non lubed?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
MOOG/PRECISION Part # 235 U Joint - Greaseable Super-Strength; Needle Type Grease Fitting
this one after installed has a needle type grease fitting that screws into one of the joint ends so that it is not buried inside the reinstalled assembly. i use the same # for front and back. only back has gotten put in so far. the front shaft has not seen constant use like the rear and i replaced the rear because one joint was squeaking.
That there is 245,000 miles of original equipment part. never replaced during the vehicles life. gotta love it. if your is original i must insistently reccomend you get a strong u-joint tool set and a 1/2 minimum impact wrench to drive it to do the job. when it "starts" to break loose you will hear a large bang for each yoke axis you do. ifg a press is used i would go 4-ton at least but maybe 8 is better.
slipping
slipping
Rosamond, CA
Thank you very much good sir! I'll keep this for sure. Its not squeaking or anything , wasn't sure if I should change. I have 186000+ so I just want to make sure all my stuff is straight. The PO wasn't kind to this hoe. I want to get new plugs wires cap belts. Going to get new k&n cai off amazon as well because I'm not fond of the one that's on it.
SunlitComet
OBS Jedi-Do Good
slipping
slipping
Rosamond, CA
Awesome thanks for the list. I will be ordering some in the morn. I already have the know and the spider you posted up in a link in my want list. Cool dude.:D
SunlitComet
OBS Jedi-Do Good
act on the k&n now that is the lowest i have seen it lately. and the spider is on the high end of pricing for the last few week.
---------- Post added at 09:44 PM ---------- Previous post was at 09:43 PM ----------
oops did not realize you had spider.
19Yukon97
Texas
Im in the process of doing ball joints on my truck... The uppers took me an hour to do. The lowers are a different story. I have a 4X4, so mine are pressed in bearings. I dont think the 2wd trucks have pressed in bearings. So you have should be fine on difficulty. The pressed in bearings are a poor design being it is very hard to press these in. Moog parts are top notch parts. I have replaced everything steering wise with moog parts. Dad's racecar has all mood parts. I actually snapped a duralast idler arm in half with a hammer. Had all the duralast parts in the truck, when that idler arm broke i took all the parts back and told them to give me Moog. lol
slipping
slipping
Rosamond, CA
I want a race car. Haha. OK thanks man!
SunlitComet
OBS Jedi-Do Good
Preggapped at .060.
---------- Post added at 09:06 PM ---------- Previous post was at 09:03 PM ----------
And burn that harbor freight flyer.
imi4tth3w
Texas
there is absolutely nothing wrong with harbor freight? i mean if you own a shop and need tools, stay far away, but for the average weekend mechanic, they are great.
as far as all your parts go, check out rock auto prices. if your a member at gmfs, they have a vendor section with a 5% off discount code.
I literally just finished replacing my inner/outer tie rods, pitman, idler arm, and idler assembly with moog parts. also did timken wheel bearings/hubs and just an autozone rebuilt steering gear/gear box.
slipping
slipping
Rosamond, CA
I'll be ordering all my Moog stuff after Christmas when my drained funds come back.
I've had to use hf when right in the middle of something and either didn't have what I needed for the one time use or broke right in the middle because they are right down the street. I like my craftsman and snap on for home and work though.
SuburbanPassion95
