New Aeromotive Stealth 340 fuel pump upgrade
JKmotorsports
Austin, TX
I finally received my new pump. Took almost a month trying to find someone who actually had it in stock. I ordered from three different places that waited until after I ordered the pump for them to tell me it's on manufacturer backorder til late April/early May. Then I finally found someone who had one left in stock.
This is a new pump from Aeromotive that fits in a lot of stock applications with little to no mods, yet flows 2-3 times more than stock pumps at the same psi and voltage, and more than the common Walbro 255 upgrade (340 lph compared to Walbro's 255 lph). I dropped the tank yesterday and had to modify the stock bucket slightly to slide the pump sock into place. This pump draws more current than stock, so I ran a dedicated 10ga power wire from the battery to a relay to power the pump. I meant to do a tech write-up but ended up almost finishing the install before I remembered to take pics.
I noticed the engine started instantly and pressure jumped up immediately as soon as I turned on the ign, much quicker than with the stock pump. I havent got on it WOT but will soon. Another plus, you can't even here the pump at all. If it wasn't for my fuel pressure gauge showing pressure, I would have thought the pump wasn't turning on.
Physh1
How much did that sucker cost you? A dead quiet pump would be nice :)...unfortunately I just replaced mine...lol...
Cameron
---------- Post added at 10:50 AM ---------- Previous post was at 10:49 AM ----------
Nevermind...just googled it...lol...that's very reasonable for a performance pump...
Cameron
JKmotorsports
JKmotorsports
Austin, TX
For about $180 the price isn't bad at all, especially from a good aftermarket company like Aeromotive. When you look at stock replacements, most of them are the entire assembly with sender, bucket, etc, and cost 2-3 times more. You have to mod the bucket to fit this pump, but well worth it if you need a hi-perf pump.
Rivieraracing
That is indeed a good price for a good pump, too bad they are soo backordered and hard to find in stock!
Phantomx55
Slow
New Jersey
Sorry to dig this up from so long ago, but which fuel pump is it? There are 3 labeled center inlet, offset inlet, offset inlet & outlet. My current pump is dying and I need to upgrade anyway for s/c setup.
Drewphil
