No it’s blinker fluid lol. No I know some people are stupid as hell so gotta ask. I ended up fixing it. Not sure what it was out of all the stuff I did but only thing I didn’t do was rear main. So it was either pan gasket or oil sensor. An a few good oil changes if anything but Mobil one an it went awayProbably a stupid question but I assume you confirmed it is engine oil. That will definitely help.
In a situation like this, your best friend is brake cleaner. You need to spray the areas involved heavily then wipe it down in every nook and cranny you can reach. Make the suspected area shine and work your way away from the suspected area as it could be dripping from a different spot. Once you are thoroughly cleaned up and wiped up as well ( notice the word thoroughly ), then take it for a 5 mile drive and crawl underneath to see what is up. If nothing shows up right away, wait for it to get cold again and then crawl underneath again. Look in the crannys everywhere to see if you see a drip forming. When you finally see the drip follow it to it's source. If it is dripping from the bell housing of the tranny, then well you have to make some decisions. Take your time and you will locate the issue.
