need help on rear air bagged
cruz_22
lame j town
i been looking n cant find any help how to bagged my rear to layed frame what setup to do send me pic of some 2002 suburban rear setups please thanks to may concern
TEXAS DEMON
with a vengeance
texas
check www.killerridez.com they havesome work. but there is alot shit load of work involved to get to lay. first you hace to step notch the rear frame and to do that you need to cut into the rear cab section so the frame will go throuhg. then you need to have the right wheels to tuck in if not you need to narrow the differential. but that all depends on the size of rims. if you use a 22" rim it ill be a lot easier, but if you want 24" and up get ready to cut alot or spend some money. the front is all about making room in the engine comparterment for the wheels to tuck in. its not that hard. just anoying removing the fuse box and them the battery. you will also need to get rid of the factory air inatke. but this is only a fraction of the work that you need.
MOBmentality
Has a $25,000 Punch
No one wanted to reply because there are 1000 threads on this already.. and some of us who really put time and effort into doing our best to answer a question above and beyond what some would come to expect.. feel like its a waste of our time.. when someone comes and asks the same question again.. instead of using the search function and looking through some of the amazing write-ups on this board...
That being said.. if youre satisfied with laying running board on 24s.. then i have a killer setup im stripping off my wifes ride that will put you with everything you need but the fenders rolled, c notch, supplemental 2 link , and front brackets...
JamesinAbilene
