Thats what I thought you have a OBS model I will move this to the correct section .
Here is one of your options CALL THEM FIRST but I'm 90% sure this will fit your truck I want to say any Lift for a 1995-99 yukon/tahoe with autotrac will fit your truck again I would contact the Dealer First to make sure before purchasing
heres a Link to zones 3 inch body lift which again 90% sure will fit with no issues
http://zoneoffroad.com/product?ki=235&gr=-1
I don't believe this will alone be enough to fit 35s even on a stock Tire But maybe with a mild crank in the TBs would help you clear them Ive seen it done . But only on a stock Rim once you start with aftermarket rims and bigger backspacing you will run into issues in a hurry . Again don't recommend it . as Cranking your keys will cause excessive wear on your front end parts. this kit will fit 33s Perfectly
If I were you I would simply Buy a True Lift kit ITS WORTH IT esp if your going to a 35inch tire . Plus as soon as you do you will want to go higher a 6 inch Kit on these trucks is perfect Rough country makes a lift that goes for 1000 , (don't know if this includes a new driveshaft Im sure it doesn't )
---------- Post added at 12:19 PM ---------- Previous post was at 12:17 PM ----------
Moved to the correct Section
