Neat lowering idea....
MOBmentality
Has a $25,000 Punch
They have my stuff disassembled.. and since we already had the lower bag brackets on the rear and the panhard delete.. instead of buying lowering springs we just added a piece of pipe to hold the spring in place and installed stock springs in place of the rear bags.. doing this lowered the truck 3 inches on a stock spring.....
see where im going with this.......
so im thinking... lower control arms , keys and spindles on the front (up to -8)
and behind the axle spring kit in the rear.. with a 5 inch drop spring and panhard delete and a cnotch for a -8 drop.. but still the ride quality of a -5 spring
so you can do a static 8/8 drop pretty easy this way.. 8/10 with a qa1 spring
devastatingly low for a static drop on a driver.. but im just sayin
Just thought it was a neat idea...
Modded
That Guy
8/8 on static drop would kill to much ride height lol.
Wonder what it looks like, any pics?
Badluck
SE WI
mob
you need to get some pics of this set-up. I would love to see some of your old bag set-up also.
MOBmentality
MOBmentality
Has a $25,000 Punch
no pics.. my truck is still in lakeland.. and im not sure its coming back here.. but its not about the 8 inch drop persei its about being ABLE to do it.. and being able to do it on a bigger spring.. maintains the ride quality we lose on trying to run the smaller and smaller springs.. like .. a -3 progressive ride spring will drop it -6 but still ride like a -3
---------- Post added at 08:22 PM ---------- Previous post was at 08:21 PM ----------
ill get some pics of it with the stock spring in before it goes back
Badluck
SE WI
I know what your saying and like the idea. Just want to see the upper spring/bag mounts for a behind the axle set-up.
MOBmentality
MOBmentality
Has a $25,000 Punch
word ill take pics as soon as i pick it up.. you DO need to do a rear trailing arm set (2 link) since there will be no room for a panhard bar.. im not saying its a super cheap way to do it.. but it is a way.. and it WILL ride a million times better than a BOA spring that is 3 inches shorter..
minitrucker
Hey MOB, i bought your drop springs a while back and i'm just getting around to putting them in. What did you do to do away with the panhard bar and what needs to be done about the trailing arms with 5" of drop?
ballsie
austin texas
Mob, Why are you selling all your air ride stuff? I am not on much anymore and I guess I missed the thread.
MOBmentality
MOBmentality
Has a $25,000 Punch
the DJM relocater kit works wonders for the trailing arms.. but im not 10,000% is nessacary at -5.. a free travel mod however.. is..
And you can keep the panhard.. but what i did was get a piece of stell tube.. and 4 reducers and heim joints and mounting tabs.. and did a 2 link from the rear portion of frame to the pumpkin at a super hard angle.. and threw the panhard away
I wanna do a very specific theme that requires a chevy as opposed to a gm.. and i ran into a position to swap mystuff back to static drop.. and trade it for an 06 c230 sport benz with about $4000 in equity as far as low blue book vs price owed..so i jumped on it.. ill be scooping an 07 salvage hoe around march
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
Well it would ride like a 3" taller spring until it bottomed out. The reason for the stiffer springs is because of the restriction in travel, not physical limitations.
MOBmentality
MOBmentality
Has a $25,000 Punch
You would still need to cnotch it if you were gonna try to hammer it... i wasnt addressing the clearance issues as much as the limitations of room in the "spring over axle" setup.. by using different mounts and creating a lower profile mounting situation you allow yourself to run more spring.. so you get a better ride.. clearance issues are clearance issues..
The ability to run a 5 inch drop spring and get an 8 inch drop.. or even a stock spring and ride to get down 3.. is just a comment on the physics of spring height and how they could be used in a different way.. as opposed to all of us wondering how to run a smaller and smaller spring.. using the spring to our advantage and modifying the mounts...
You are right though.. running a softer spring to get down 5 as opposed to the stiffer 5 inch drop.. could create a situation where axle to frame issues COULD be more prevalent.. even with stiffer shocks.. but.. im assuming anyone who went though this amount of fab to get an extra few inches and abetter ride out of it.. will probably do a cnotch and alleviate the clearance situation right from jump...
Badluck
SE WI
Don't forget about the pumpkin and floorboard.
Axle to frame can be fixed with a c-notch....pumpkin to floorboard requires some sheet metal work. This is the issue I am going to be dealing with. As laid out now, I'll have around 3" before the pumpkin meets the floorboard.
MOBmentality
MOBmentality
Has a $25,000 Punch
lol we are still talking a STATIC drop.. lol.. not THAT low... besides on 24s the wheels lock out WAY before the pumpkin.. and actually you will hit drive shaft before pumpkin.. or maybe they hit at the same time... i never got under it when it was that low.. but on 22s.. i could drive with it slammed.. but the nose on the driveshaft would smack the shit out of something down there ....
rigo_jones
going against
DENVER mexico
mob if you could take a pic or show me something similar on how you deleted the panhard bar would be great.please.
also this might sound ghetto but if you cut the stock spring and modify it the way i did it rides like stock 100 times better than the qa1s. when i tried it i was at the same ride height as the 10-350 qa1 spring took it for a ride and what a difference seriously.
it does not bounce up and down like people told me it would. i mean its like stock maybe a lil better than stock probably because the way i modified it. now if i put some bags in between the springs it would be good for towing but with stock cut springs are not needed for normal driving.
oh btw theres a secrete to this... dont just cut it and install it.
Badluck
SE WI
I'm going for a super low static drop. You still have to deal with suspension travel. I'm running 275 skinnys on my 24s so it's even harder to eliminate more gap between tire and fender. I plan on doing a lot of cutting. I also noticed that the upper spring mount has to be cut to do the c-notch.
MOBmentality
MOBmentality
Has a $25,000 Punch
im not sure how low youre talking.. but with a c notch .. djm relocters.. behind the axle setup and rear 2 link (aka panhard delete) and 295/35/24s i was about 2 inches from running board (WAY lower than i can imagine being at static) and i was locked out at the tire... not the suspension.. and with 22s.. i could lay running board and even then i was locked out at the driveshaft (and maybe the pumpkin..
But again.. thats way too low to be static imo anyway.. thats pretty much pulling the stock pring out and laying spring perch to spring perch.
Dropping 7-8 inches with a behind the axle setup with a -5 spring. .should be pretty safe..
another alternative is doing a remote mounted panhard bar.. that is... mounting the panhard out further behind the axle to make room for the springs.. and stiffening the supports.
Badluck
SE WI
When I get shop time, I'll post pics of the surgery. I have the McGaughy's relocators installed from my 3/5 kit. I'm waiting for my adjustable pan hard bar and am working on a set of used shock extenders.
There is room to do front mounted bag brackets and you would be able to keep the pan hard bar. If my planned set-up doesn't work, I'll explore my options this way.
MOBmentality
MOBmentality
Has a $25,000 Punch
room to do it front mounted? If youre going that low your gas tank is gonna be in the way like.. NOW.. Part of having a pan hard. is when you tuck it shifting back and forth can cause issues.. some people are only tucking with 1/16 of an inch clearance on each side.. and thats too little to compensate for panhard slide when it lifts back up
Eagle
EL PASO, TX
Mob, why not a Watts link?
It'll keep it perfectly centered all the way up and down.
I think there is even a kit at suicide doors.com (or somewhere for 67 Chevys?)
that is one app where Watts makes perfect sense.
MOBmentality
MOBmentality
Has a $25,000 Punch
sooo true.. and i LOVE them .. but i have heard so many leak storys that it has me scared
PexoA78
