My New Project
bigal11419
bigal11419
Queens, NY
As soon as I get a nice Saturday or Sunday that it doesn't rain or my wife doesn't already have plans for us I have a Volant CAI, some new horns and all the parts to do the Big 3 upgrade waiting to go.
bigal11419
bigal11419
Queens, NY
Still haven't gotten to the last batch of parts and I order another batch. D they have a 12 step program for Tahoe addictions? Since I already put a new pitman arm and gearbox in for the steering I ordered the rest of the parts for the steering. Got all Moog parts from outer tie rod end to outer tie rod end. Got new tail lights and the last of the parts to finish my denali console and get the subwoofer working.
bigal11419
bigal11419
Queens, NY
Install a new Goodyear gatorback belt, new anzo led taillight assemblies and a new mode door actuator
bigal11419
bigal11419
Queens, NY
Another batch of parts installed this weekend. Put a new idler pulley and tensioner pulley. Replaced the fan clutch and fan because the old one was seized up. Cleaned the throttle body and the MAF sensor and replaced both batteries with 800CCA Duralast Golds. While I was screwing around checked and charged the A/C.
Dneel81
OKC
Keep it up. I'm living vicariously through you.
RAWVORTEC
Lburg
Do you have a list of the things you replaced in your front end? I'd love to tighten everything up this spring.
bigal11419
bigal11419
Queens, NY
No problem I'll add that tomorrow night when I update the post
Sent from my SAMSUNG-SM-G920A using Tapatalk
Dneel81
OKC
Just did mine
Idler arm with new support bracket thingiemabob
pitman arm (34mm socket and impact necessary)
upper control arm bushings
lower control arm bushings
new shocks (bilstein 5100)
upper and lower ball joints
new tie rods (inner and outer)
new sway bar bushings
new sway bar support rods
Make sure your son doesn't mess with the steering wheel while everything is apart...makes things trickier than necessary.
ZaZaZazzels
