TerryKing
My 2012 Tahoe has a place for a secondary battery.
Can someone point to How-To install / wire a second battery??
Thanks!
Thanks!
Not an option on the gas vehicles (usually standard on diesel because of the starter requirements of high compression engine). What OP is talking about is the presence of a second battery tray (although empty). As already mentioned some folks add a second battery and connect as described.Is this an option only for ppv vehicles? I have only had dual batteries on my diesel trucks.
All nnbs doMine has a second battery tray as well
Yes, it IS an option for the PPV. It's usually a 730 CCA auxili
IIRC, all Tahoes come with two trays, but you only get the battery and cabling if your truck has the optional auxiliary battery. I don't remember what the SEO option is for that.
Ha, I forgot to post....
I mounted my siren speaker thereI have it on my 09 LT. I had a roll of blue shop towels bungeed there but they kept getting wet.
The front corner of mine is dedicated to my catch can now. I may still find a way to keep a roll of paper towels there and dry. So much easier to have them handy to check your fluid levels.I mounted my siren speaker there
Ziplock bag?you could probably get a section of 6in PVC pipe with some ends to store your paper towels and mount it on the battery tray
My 2011 SSV came with two batteries. Crazy secondary wiring harness was installed at the factory. Second battery is for light bars, strobes, radios, etc. Best part is that you can give a jump start from either side of the vehicle.
Factory single is in passenger rear location, extra is front drivers. If parallel setup both start vehicle so remove positive fronm second battery down to starter and neg to alt bracket.I have a 2013 SSV. Which battery of the two starts the truck? I'd prefer to only have one battery if I can get by.
