Most offset on 35s?
rmanTX
We have a 21 4x4 and I'm looking to lift it on 35s, curious what the most offset I can fit in there is without trimming metal.
I'm not necessarily looking for more poke, just trying to open up my wheel selection a bit.
From what I've seen, 0 seems to be the comfort zone. Curious if anyone has fit a -12 or -18 with the standard fender pullback and front liner trimming.
Thanks!
Trey Hardy
Thanks!
Once you lift it I recommend -44 offset or more if not it’ll kind of look funny being so tall with skinny ass wheels and tires but that’s personal preference I run 14” wides -76 offset AND wheel spacers on everything I own lol
CCPLuvr
I believe factory wheel offset is +28mm. a 0 offset will move the wheel centerline out just over 1". If you use that thinking along with the tire width difference you'll get a very close measurement on how much poke you'll have.
R
rmanTX
yep, that's correct. I see most lift on 35s with a 3" lift and 0 offset. Just curious if I can get away with a little more negative offset.
snives
Chicago
My PPV is on the factory 17" steel wheels which are +24mm offset I believe. I needed to add 15mm spacers, and do the norcal mod.
snives
Chicago
It's detailed on other sites but, but in general its how to cut the inner wheel well (cab side) where it would usually rub.
Towmaster
