Misfire on new motor
Hello,
Installed a new GoodWrench 350 into my 99 gmc yukon. New dizzy, wires, plugs spider MFI. I set the cam retard to 0 and the cap is turned all the way to the right and touched the intake to reach 0 degress. I'm getting the biggest misses on number 2, with number 4 then number 3. The misses havent been enough to throw a code as of yet. Here is the head scratcher i have. The crank learn test wont register the sensor. I run it up to 5k and let off as the scanner is waiting to see it. I have two shims on the sensor is that to many for it to get a reading? Another odd thing to mention is when the dizzy is set to reach 0 cam retard it's pointing more to number 3 cylinder. If i stab it pointing to number 1 cylinder i can only get the cam retard down to +8. I have also heard that GM is saying to run plug gap at .45 instead of .60, is this true? Mine are at .60. Any ideas would be great.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i suggest you re read the install procedure for the dizzy you need a proper scanner to set cam_retard. you can not set it to zero and say it is pointing at #3. your our doing something really wrong there. as i read it anyway, but i am very tired at the moment.
---------- Post added at 10:16 PM ---------- Previous post was at 10:15 PM ----------
and.060 only. your are reading info that does not apply to your vehicle engine.
P
Im using a Solus scanner by snap on. I was able to get the CPK learn completed. The cam retard is at 0 and Im still having a miss on #2 cyl. Its pretty frustrating that I'm having this miss issue.
Phone Man
Long Island NY
I think you have to have your foot on the brake at the same time your raising the rmp. Should cut out at 4k.
P
Okay, I'm going to restab the dizzy tomorrow so it points to #1 cyl. At that point what should the range be for 0'ing out the cam retard?Should you see a range from say +10 - -10? On the old motor had 180K on it and I was having a misfire on several cyl. I seem to have the same issue with the new motor. The things that i brought over to the goodwrench 350 long block were the lower intake, MAP, MAF, EGR, ESC, CPK sensors. The misfires dont cause the CEL to come on but i see them on the scanner. I have cleaned the MAF and checked resistance and voltages on the other sensors all check out okay. Could the ESC cause a crossfire? i am thinking i could be dealing with a crosfire issue. #2 cyl is taking most of the misfires with #4 and #3 having fewer. Where should i try to eliminate the issue at?
SunlitComet
OBS Jedi-Do Good
With engine at tdc on at beginning of power stroke, crank pointing at 0 timing mark the dizzy rotors should rest on the 8 mark ( may look like. Pyramid too) on dizzy housing with the cap towers pointing sideways with a slight clockwise maybe. Once aligned clamp it down slight. At hot temps for a 99 unit check the cam_retard at 2 and 4000 rpm. Adjust as need at 2000 rpm to achieve 0.0 degrees but you go 2.0 higher or lower. Verify at 4k. Clamp for good. Any crossfire after that is misplaced wires or dAmaged cap. Missing could be bad wire or .plug or bad cap. Once retard is set properly and you don't "feel" misfires perform your crank relearn again. You may have set it with a mis alignment causing false errors. Rinse and repeat as needed till you are proficient.
---------- Post added at 04:08 AM ---------- Previous post was at 04:07 AM ----------
BTW use Delphi or delco caps and rotors.
Phone Man
Long Island NY
I'm curious as to what you find as a solution. I've been having misfires for a year and have changed everything. Spark gap at .045 was worse than .060 for me.
SunlitComet
OBS Jedi-Do Good
Vortec 350 are platinum 41-993 pregapped at .060, DO NOT ALTER the gap. If your vortec 350 will not operate with that then something else is wrong.
P
I will let you all know how it turns out. Wifes birthday today so no working on the truck.
P
Okay, I restabed the dizzy to point at number 1 cyl. I have the dizzy turned as far clockwise as i can and it sits at 2 for the cam retard. Number 6 plug wire barely has enough to reach the dizzy. I did the relearn on the cpk and im still getting misfires on 2,3 and 4 cyl. I have placed two pics on snapfish and hopefully have the link imbedded in this reply. Have a look and let me know what you guys think.
http://www5.snapfish.com/snapfish/t...otsc=SHR/otsi=SALBlink/COBRAND_NAME=snapfish/
SunlitComet
OBS Jedi-Do Good
yeah pics ain't happening. something aint right tho if you have to crank it over as much as possible. aren't you using the alignment narks on dizzy gear and body to set it up for install?
P
I have it as it should be. I will make a video tomorrow and post on YouTube. I will show rotor position, timing mark for tdc and the cam_retard position. I will also shoot video on the miss I'm getting.
Phone Man
Long Island NY
Something is really wrong if the wire isn't reaching. Get #1 at TDC by pulling the#1 plug and turn the motor over by hand. Put your finger in the hole. As you get close to 0 on the timing, air should rush out. Then drop the dist in when the 0 lines up.
Otherwise perhaps the timing marks are off on the cam and crank gears under the timing cover. Just a guess but it could be a factory mistake.
P
I was thinking the same that the mark may be off on the timing gears. Would one tooth off be close enough to run?
P
Just reading another forum, and maybe this is my issue. When i have been saying i have the rotor pointing at #1 cyl., i ment #1 spark plug in the block. Should i be having the rotor pointing to the #1 tower in the distributor cap?
SunlitComet
OBS Jedi-Do Good
uh, sort of. it needs to point to internal cap terminal of cylinder #1. remember not not every terminal inside coincides with terminal directly near it on outsides terminal. iirc when mine had its cap removed and i followed the procedure the rotor technically was pointing towards the very bark of the brake booster. but the terminal was number in the cap terminal on the outside because how the cap routes it.
CKendrick
