magnaflow catalytic converters
hassoun
Germantown, MD
hey guys any of you are using magna flow cats in a 01 Denali ? for some reason their site has 02+ but not 01 ?even ebay has the same thing. they have cats for 5.3 base yukon. what part number should i use for mine?
nikel
one quick note. I have a 98 Hoe and I thought my cats were a restriction problem. To test this I took them off (entire front exhaust section). I then took my shop vac; which will translate a change in air flow to sound (think about when it gets clogged) I used a narrowed adapter for the hose and sucked air through the cat. No change in air flow.
Now I do not know what the newer cats are like, so they may be more restrictive, but new cats are expensive. I would think that headers and a more open catback exhaust are a better investment.
Just my 2cents.
YUOnDaGround
Central Virginia
With a restriction like the cats, I can't see how you would see a difference in performance going with Headers. The point of the header is to get the exhaust gases out in a more efficient and free flowing manner. So when you put a cork (Catalytic Converter) right after it, what gains can you get? Seat of the pants dyno doesn't count. I want a dyno chart.
---------- Post added at 01:08 PM ---------- Previous post was at 01:06 PM ----------
If I were you and wanted to replace the cats, just measure the exhaust pipe diameter, which I think is 2.5" (check for yourself) then just buy two of the magnaflow universal cats of the same diameter. I have a 2002 Tahoe and my cats are fairly accessible so the welding shop shouldn't have much trouble.
Zed 71
Pacific NW
Stock cats have sufficient flow for your mods. Are you replacing because they are spent/damaged?
hassoun
hassoun
Germantown, MD
my cats were shot thats why i had to change them. i agree u wont notice any gains unless you change your headers. in my situation i noticed some gains due to my clogged up cats.
dizhai
