lowered my 04
NORCAL SS
SUV SUSPENSION GURU
BTW the 5305 gives almost a 5 inch drop. 4.5 at least from stock. Your truck if not sitting on bumpsstops should be a lot lower if it's the 5305 spring with shock extenders.
Falze
Falze
I'm goin to get under it today n check it out. I kno b4 I was just above the bump stops but I will look at it some more today
NORCAL SS
SUV SUSPENSION GURU
no problem. yah just look at springs to make sure they say 5305 on them
Falze
Falze
Springs r the 5305 n I'm about 1/2 to 3/4" above the bump stops.
NORCAL SS
SUV SUSPENSION GURU
wow must ride harsh. I would do the free travel mod/djm links/my bumpstops. What shocks are you using on the truck?
Falze
Falze
Stock shocks with extenders. Actually ride good I think, just wish it was lower.
M Hankel
Vancouver, WA
Like Tony said, do the free travel mod for sure. Do your springs have the 1" spacer installed? If so, that might be why yours is sitting a bit higher. Mine are 5305 springs also but I'm not using the 1" spacer. Mine has the free travel mod but I can't remember how far my axle is from the frame. I can find out if you need it.
If you find out they don't have the spacer installed you can always trim off a couple dead coils to get a lower drop for the back without sacrificing ride quality. One of the nice things about the 5305's.
Mike
Falze
Falze
What is the free travel mode consist of or what is it also no spacer on the spring.
M Hankel
Vancouver, WA
Free travel mod is just cutting off the metal section of the rear bump stop all the way up to the frame rail in the rear, right above the axle, both sides.
Mike
Falze
Falze
Thanks for all the help will be doing the free travel mod soon..hope it helps
Plus the bumpstops i have are shorter ones that came in the kit..
Falze
Falze
Is there a kit with just the shorter links for the sway bar
Falze
Falze
Unhooked my sway bar Tahoe went down not quit a half inch. Have to the end links n see what happens idk
jpmire
Lafayette, La
3/4 drop on gmc 20s. Did free travel mod and short bump stops. Found that my stock shocks were not allowing me to get a full 4". So ran bell tech drop shocks.
attachment.php
swtz71
Mass
That looks sweet
Falze
Falze
Looks good, n that is the same wheel I was lookin at. Looks like I order some shock n end links. How did u get the 3" drop?? Thanks
NORCAL SS
SUV SUSPENSION GURU
belltech 5305 springs with 1 inch spacer 3-4 adjustable
CKendrick
