Looking for brake advice (upgrading)
Mr.Martin
NC
Ok, to start with I have had my Tahoe since I was 21 (27 1/2 now) and I have never replaced the rotors and only changed the pads once about 3-4 years ago! Pads are still great but the rotors need to be put down lol. What I have been looking into is the power slo plus kit (14" rotors), ssb brake lines, fluid change and Hawk or EBC pads. I have large enough wheels so that's already been taken care of.
I have heard lots of good reviews for the rotors except for the price, but now I need advice about the best pads to get...Hawk or EBC and which model pad to get. Also, who's got the best ssb hoses. The main question is, does anyone know the best, and cheapest place to order this stuff? Anyone have any hookups?
blueflamed03
Oklahoma
what about these from NAPA
http://www.napaonline.com/Search/De...030+2030087+11011+599999+109999+59999+3999999
Part Number: UP PR86825R
$124 each, simple bolt on.
M
Mr.Martin
NC
Looking to upgrade to a bigger rotor with out spending 3k so the power slot 14" rotors looked like the best deal.
oakrdrs187
Coachella,CA
I think our friend wants a direct bolt on that he can just buy with out scrambling through salvage yards or stealerships, I too have been looking into the plus kit, but not sure which pads to go with. my rotors are warped as of now so they gotta go.
blueflamed03
Oklahoma
the ones above, and the NNBS I mentioned are bolt on.
dwmmatt23
central valley cali
I was going to do the nnbs upgrade on mine to get a little bigger rotor, those powerslot plus kits look pretty good, any idea about how much they run?
Ryan Willson
San Jose, CA
I've personally found the Hawk Yellow pads to be pretty awesome. They are a bit on the pricey side but the wear is great and pretty rotor friendly.
Also, I upgraded to the Brembo Slotted rotors. I had a set of drilled on a vehicle once and they had a tendency to stress crack easier.
Just my $.02...
tucsonlocal
laguna beach, ca
because the eradispeed +1 is a direct bolt on, and so is the NNBS caliper, can you get the eradispeed +1 for the NNBS and put it on the NBS for 2" rotor size gain in front?? Hmmmm..
ILLEGAL REGAL
Tinley Park, IL
if you're wanting Baer let me know, might be able to help save ya a few bucks.
I was looking to do the 6 piston 15" fronts and alumasport 14" rears if they'd clear my wheels, then I gotta find at minimum 20's for winter use or spares. I came across a deal to get that whole setup for 2k
Volant1
Volant guy
Upland, CA
Do you know if you have a single piston or dual piston rear calipers? My tahoe had singles and I swapped them for the police addition rears off a 03 which were duals, I run EBC rotors and pads there slotted and spot drilled I also run there yellow pads, its the poor mans solution if you didnt want to spend 2k on brakes, I might have 200 bucks into it
