lets talk drop
DJTricky
Banned
Robbinsdale MN
ok so i started my drop. I have the front end done. And i want to go lower. But being 4x4 i cant do much more that i have already done. Anyone else on here lower a 4x4? Its 3.5 inches lower in the front and will be 4 lower in the rear.
Modded
That Guy
Oh o some people are gonna start crapping on you for lowering a 4*4, but I think people all over here have lower z71's and regular Tahoes, look around a bit.
I do know you should have no problems lowering it though, just like any other 2WD but suspension gurus like Max can confirm.....
D
DJTricky
Banned
Robbinsdale MN
haha yes i am lowering a 4 wheel drive. But you cant lower it like a 2 wheel drive. They use coil springs up front. 4 uses bars. And i have already done keys and the decrank. What ere can i do to get more drop
foreverfalcon40
I just did keys and a crank and Its as low as I can go! Happy with my setup! If I hit nice bump at a decent speed I'm rubbing.
bowtiefreak
No Quarter
Near Philly
really tiny wheels and tires, a nice set of 10" would get you a bit lower. Lift it, fat chicks can't jump!
on a serious note try the new keys and did you flip the axel in the back? when I say flip I mean pu it inside the leafs instead of under. That will get you lower in the rear.
nc6600
ps trucks in drive
Cary/Apex NC
Hold on crap coming.
roadrageror
ROADRAGEROR
alberta,canada
I just dropped my 99 Denali 4" front and rear. It's a 4x4 and it looks pro!! I used a bell tech kit. I had to get smaller tires 265.30.22 instead of the 305.40.22 I had. I wouldn't want mine any lower no rub no problems...except it is alot stiffer ride. Roadrageror @ car domain pics of before and after thanks. Only problem is next year when I try to fit 26s I might have to tweek a few things. Better to lower a 4x4 than lift a 2wd I say but to each his own!
bowtiefreak
No Quarter
Near Philly
I think the lift the 4x4 and lower the 4x2 is an whole other thread and will be split 50/50. Like it was said, to each it own. If it makes you happy...then it is good. Unique anything has the potential to be cool
D
DJTricky
Banned
Robbinsdale MN
you guys wanna see my newest project. Its 4x4 also. 6 inch front and 8 rear. Im still working on my hoe but this is my buddys. Mine is right now at a 4/4 drop
foreverfalcon40
Bahh to small of wheels!
DJ...Like your truck...please loose the altezzas!
I SAY KEEP DROPPIN *****!
Ninety5PoloZ
Wisconsin
Details????? How did you get a 6" drop in the front? The rear would be easy, flip and a shackle, but I bet alot of cutting would be required to get it to travel without hitting on something.
Or is the blue one bagged?
clean454
where did u get ur tortion keys from? do u have to do a flip kit in the rear just to get a little lower?
ZaZaZazzels
