Led
Queretano
I have a question. how to run more wires for more interior lights to install.more leds
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
If you want it hidden then you are going to have to run in the overhead and that will be a bunch of work dropping that down and running wiring depending on if you want the lights away from the edges. Or just along and under the trim around the top. All depends on where the lights will be positioned.
Q
Queretano
Physh1
The grey wire with the black stripe is the power wire. Ground everything to the dash frame.
Cameron
Bwaldron
