Leak behind passenger area dash
totalpackage
Let me start out by saying i have read at least 3 other posts on this common leak problem. I have had water on floor board for years. My cowl was dingy and cracked so i took care of 2 things at once by sealing the 2 screws and replacing all the cowl parts. It stopped majority of water but i still have water getting in on the right side. It runs down right of the blower cover on top of the beige panel i am pointing at. It runs down to the side door step area and fills up till it touches carpet and carpet absorbes it and brings it in. I trimmed back some of the carpet and thought about drilling weep holes but wanted to show this pic to see if anyone else had this exact area issue.
I def wouldn't drill any weep boles in the floor. I had a similar problem recently on a long trip. It was super hot and humid and the ac was on the entire trip, which was almost 800 miles. Condensation formed on the box behind the glove box and was occasionally dripping on the passenger side floor. After awhile it would occasionally drip onto the drivers side floor. Think it's a similar situation with you?
Ahhh, OK. I'd take the cowl off again and silicone the hell out of it. Especially where the factory used body sealer at. Over time that stuff can get brittle and chip off due to body flex, causing leaks. I'm not saying that's your issue, but it would be somewhere to start.
rushtk
Athens Ohio
i had to re seal my ac box against the firewall, the hose to the outside was free of debris but the leak wrecked havoc on my carpet. had to replace it. siliconed the crap out of it and no leak.
rushtk
Athens Ohio
I'm the 2nd owner and my buddy and his family are a little messy. We thought thats why it was so stained, I went to change out the blower and resistor and was soaked. i've had it since Oct 1st 2014 and never noticed. had to toss all the carpet and padding and take care of some rust specks. hope it stays fixed with everything I just did in it.
totalpackage
totalpackage
Thx guys, im thinking mine is still in the screws under cowl. I will try and reseal again.
totalpackage
totalpackage
ok, im attaching pics to see if anyone had this leak issue with some marked up pics. Anyone had puddling under step pad from the door gasket? The large red arrow shows the only current spot i see water dripping after the storm. Maybe running down inside of gasket?
east302
Mississippi
How well does that door shut? Does it sag?
Is the headliner wet (windshield seal)?
You might try coating the gasket with baby powder or baking soda and then run a water hose over it to see if you can spot where the water is coming in.
totalpackage
totalpackage
Yes, the headliner on that side started getting damp, maybe its all related but the water is currently sloshing around when it rains..what a pain.
east302
Mississippi
If the headliner is wet, I’d look at the windshield seal then as the water could easily run down the a-pillar to the floor.
JeffK
