Largest tire for a stock suspension
SunlitComet
OBS Jedi-Do Good
unknown at this time.
What is the largest tire for a stock suspension anyone has tried with no modifications to tire or body?
Vehicle details below.
Someone has already put lt265/75's over the stock 245/75's going to take it back to it original static load radius but would like more width.
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
285/75/16 will give you no issues and will fit on a stock suspension with no modifications. You could run a 305/70/16 tire with slight rubbing and may need to crank the bars a bit.
285/75/16=33x11.50x16
305/70/16=33x12.50x16
As you can see they are essentially the same in size but the 305 is an inch wider.
SunlitComet
SunlitComet
OBS Jedi-Do Good
Sorry, I edited my message after your post. Any ideas on my additional info.
I maybe not in the mood in the next two years to change gearing. Would like to do other things first.
Unless with my setup it can be proving I will not screw up performance at all.
I will stick with 16x8 and maybe lt285/75r16 wheels and tires I think.
Thoughts?
bowtiefreak
No Quarter
Near Philly
you will be good with that and shouldn't notice much difference. I ran that size for a while and then a 305/70/16 with stock suspension witll some rubbing though on big bumps
JPeter
