Keyless entry problem
Ilovemyyukon
I have a 2001 Yukon SLT the keyless remote started having issues where it wouldn't unlock or lock unless I was very close to the truck now it doesn't work unless I'm outside the door so I don't use it I've tried buying new key fobs off Amazon and programming them but they will not program for the truck the old one will reprogram for the truck but still has has issues I have replaced the battery and don't want to spend 150$ at the dealership
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Could be the actual keyless entry module that's in the dash underneath the board. That could be your issue, I can get you a price in the morning when I get into work.
915_Tahoe
HELL PASO, TX
THERE ARE TWO RECEIVERS FOR THAT YEAR BUT ONLY ONE IS AVAILABLE.
RUNS ABOUT $210 FOR THE MODULE NOT INCLUDING INSTALL OR PROGRAMING, BEST BET IS TO GO AFTERMARKET CHEAPER AND BETTER THEN THE FACTORY KEYLESS ENTRY.
griffey_mojo
