keep blowing #9 fuse nobdash lights No taillights!! Help!
billbies
Happened this.morning and put.new fuse in blows as soon as. U start truck its the pk lmps one and checked all bulbs are good the only thing it does do is hyper flash left turn signal and has 194 bulb flashing too
Any help is appreciated
JubjubW
Wausau, WI
I had this happen once... but in a different vehicle... I swapped the radio and a wire wasn't connected right and grounded itself out on a different piece of metal... not sure if its relevant, but figured I would throw it out there.
chauncey0337
MLT, WA
Can you try to explain what the problem is in more detail. It would also help if you used proper punctuation. It's very difficult to comprehend when the sentences run on. You might get more help if people can understand you. Just sayin.
JPeter
