It’s a goner, isn’t it?
j91z28d1
Timing gear ???
I honestly have no idea.. it's hitting something solid forsure.. but if it was a rod bearing spun, they usually get worse really quickly, have bad oil pressure and start squeaking before they lock up.
someone said torque converter bolts or flywheel. that might be a good guess. I don't think the starter driving hitting would sounds like that. Hopefully someone has a better idea than me.
SpareParts
North Idaho
What is it idling at? Warmed up it should be idling around 550 rpm.
That noise it to fast for a crank or rod knock if it is idling properly.
R
rachealae
first thing I would do is take both belts off and see if the noise goes away, doesn't sound internal to me but hard to say from a video
Thanks I’ll do that tomorrow
Idling just fine…oil pressure, rpm’s. No changes in anything.
R
rachealae
Hmm I’m bringing it to a second opinion this week. We drove it twice to a mechanic and back and no changes so far. Oil pressure, rpm’s, etc have been the same.
SpareParts
North Idaho
Now that i think about it a couple bad lifters could sound like that but both lifters would need to be bad on two cam lobes 180 degrees apart otherwise it would sound more like a double tap.
Unlikely but not a 0 chance
R
rachealae
Does it smoke??
Funny you ask. Sometimes. White smoke.
I had two mechanics check for coolant leaks twice on it because I get low on coolant on occasion. Apparently they couldn’t find anything so I gave up. When I delete AFM, it happened less frequently but still happened a couple times a year.
mountie
Maybe……
You could be burning white smoke….. sometimes, but not enough to notice, as you drive easily ?
LsHart
Senior Member
Just pull valve covers and do a jiggle test. Sounds really fast like a lifter. To me
LsHart
Senior Member
Longer u run it like that , the worst it'll get
Actifenpleinair
Sandy, UT
Could it be something rubbing on the timing chain? Like a piece of the tensioner or a piece of the cam position sensor? I mangled two Cam sensors trying to pull them out after 250k on one and only 115k on another, both 2007 L92...
NYBRD
My pushrod ate it and sounded like that just not as loud
My sound wasn't as bad but very similar
I just threw in a replacement rocker and pushrod some lifter additive for good measure just in case and its runing fine now
scottd
