intermittent fuel pump question...
noffboy69
I have a 98 yukon slt that the other day the fuel pump intermittently works. I changed out the fuel filter and the fuel pump relay. Is there anything else that I can check that may be the cause of this happening before I spend the time and $$ on the fuel pump and dropping the tank. For the record, when it does work and the truck runs....it runs well with no issues...sluggishness, loss of power....
willxfs
Something similar happened to me. Intermittent fuel pump problems. It ended up being the connector to the fuel pump. I changed it out and fuel pump has worked perfect ever since.
Freedom Motorsports
It can be the harness connector at the fuel pump which is often the case. You can inspect and attempt to service the connector by making sure it is not inundated with moisture and then put some dielectric grease in the connector to ensure that it is working properly. If that doesn't work, it can be the pump, but when they go out it is usually for good and not an intermittent problem.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
there is a ground for it to the left frame well. but the original connector design also had issues. a bunch of improvements have been made to the fuel pump and the connector type was one of them.
noffboy69
noffboy69
Thanks for all the input guys!! Guess though if I'm going to have to drop the tank to check connectors, I'll go ahead and install new delphi fuel pump while I'm there, no need in doing things twice!! lol
dizhai
