Interior over Haul
timjohnson22
timjohnson22
GEORGIA
Sorry, I had alot of things going on this week.I haven't made any progress. My amp cover is getting sanded so it can get painted. I had to buy struts from http://www.acecontrols.com/ which can handle 500 (lbs) and the ends from http://www.autopartsbylou.com/index.php in order to use the tailgate remote without any issues. The OEM struts can only handle 244 (lbs). I will post more pictures soon. Thanks!
timjohnson22
timjohnson22
GEORGIA
Ok, this is why I had to put the truck on the side for now. The new addition to the family (Julian Carter Johnson).
timjohnson22
timjohnson22
GEORGIA
Ok, time to finish the install. With the custom 500 lbs shock we cut the end of the old rear gate shock and welded it to the new. The new shock was a little short and the treads on the stock ends were M8 and the new ones were an M10. We rethreaded the end, everything worked out great. With the new shock holding 500 lbs we had to realease some of the pressure out. So I ordered and new one from Ace that lets out the air slowly this tool broke so fast because it could not handle the pressure, it broke that tool into two. I went to Homedepot to find and M10 extention and a screw so we could mount the pin to the screw tool to realease the pressure. Home depot had nothing so I went to Fastenal and ordered a custom M10 extention and a screw that feeds through the extention. (It took about 5 days to get the part) We cut a hole in the extention so the air could escape. So we screwed on the extention to the end of the shock, stuck the pin inside and started screwing the screw in the extention slowly. Air started flowing out. We tested it with the rear door with each little realease. YES, it worked. So the door opens and closes with a push of a button. BUT, SHIT we forgot to add the weight of the cover. So, now too much air was realeased. Luckly I ordered two shocks at $52.00 a POP. We mounted the cover that needs to be sanded down and rhino lined. Cut off the end of the old shock and mounted it the the second new one. Realeased some of the air and yes again it works with the cover on. it can hold another 20 lbs, so the rhino line will hold. The cover will be rhino lined at the end of the week and i will take pictures. I have to get to bed I am tired.
timjohnson22
timjohnson22
GEORGIA
Ok, the AMP install is finished. Here are some pictures 1
timjohnson22
timjohnson22
GEORGIA
pictures 2
timjohnson22
timjohnson22
GEORGIA
pictures 3
timjohnson22
timjohnson22
GEORGIA
The auto tailgate works perfect with the weight. Let me know what you think.
timjohnson22
timjohnson22
GEORGIA
pictures 4
timjohnson22
timjohnson22
GEORGIA
pictures 5
Jbird
you are way more patient then me lol i hate running all those wires and doing all that.
It looks awsome though very clean. good job
anton28
Wow now that's a project. Reminds me of when I did my stereo and headliner. Had the car all apart, looked like a theft recovery lol Great work!!!
Bob LaFord
