Interior leds
Ceejkay
Ft. Lauderdale, FL
i know this has been covered, but i still have a few questions. didnt want to bump old threads either.. i just want confirmation on which leds to use..
Cluster- 194
HVAC- t1.5
Fog light switch-?
rear hatch switch-?
headlight switch-?
push 4x4 buttons-?
Stock radio- ? also is there a way to change the screen color?
Rear wiper switch?
rear ac controls-?
garage door unit-?
im not worried about soldering if any of them have to be. just want to know the exact bulbs i have to use.. also i want to keep the stock radio, i leave my truck on the beach for hours with no one around it. i dont want a reason for someone to break a window trying to steal an aftermarket radio.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
don't have most of other switches but the rear a/c should match the 194 cluster or t-1.5 used in the front unit. i think i had the neo 4 in the head switch but a problem arises that it could not light the entire switch being not a real 360° it was two directional and even barely light the bottom of switch. i had the same issue with the from to switch modules. the rear door modules are bright as hell. have not touched the 4x4 switch as mine still lights.
Ceejkay
Ceejkay
Ft. Lauderdale, FL
right now im just looking to do what i see when i drive. i should have specified driver controlled rear ac, the one in the overhead console. i might have to hold off on the headlight switch and get one from a jy to play with to get 100% light
SunlitComet
OBS Jedi-Do Good
i know which on you meant. as for the headlight one it might be best to just stick with the standard incandescent if the experiment does not work out well.
johnsonwillie199
