HitandRunDriver
Started On the swap yesterday, and am having a couple issues...
Got the rear window switches done without a hitch, but when it comes to disassembling the front driver and passenger window switch boxes I've had no luck at all. First off I make sure to unseat all the tabs holding the top and bottom of the boxes together. Once thats done I try to pry the box apart but it will not come apart. I've had luck getting either the front or the back almost off, but I'm thrashing the plastic on these guys. It seems like there is a connection on the inside holding them together, and I'm at wits end here. Any help or pointers would be appreciated....
Just for kicks, does anyone know if i can pull out the seat heater switches to put an LED behind each without removing the entire door panel?
