odie301
Ok, a guy i work with bought a set of keys off ebay to lift a 99 up chevy truck. he thinks they were for a 3/4 ton truck?? Anyway...he bought an older style truck (97) so he gave me the keys. We installed them and i can get the front cranked up to almost level with the rear... problem is the drivers side is cranked up max and i only have 35 3/4" from ground to fender lip. Passenger side matches only passenger side screw is not maxed out. Will longer bolts help out?
SO while the keys were out i looked at the difference and the new keys were different by maybe 1/2 inch... Are these the right keys?? Did i just get my drivers side torsion bar turned wrong? I installed the keys thinking that i wouldn't need to have them cranked all the way up like my stock ones, meaning i could continue to level it out as the front settles.
I did put air lift 1000 bags into the rear coil springs...not sure if that changes the front in any way. The rear sits right at 37" inches from ground to fender lip. (measured at center of the wheel)
