Ignition Coil
95escahoe
I have a 95 Tahoe and awhile back I did a tune-up ac delco: plugs, wires, cap and rotor, pcv valve, and fuel filter, the one thing I didn't do was the ignition coil so was looking on advance auto's website (I know someone that works there so I get a discount) they have the ac delco, and they have msd too can I run the msd with the wires I have or would I have to upgrade them? and does anyone use the msd one on there Tahoe and if so what you think?
retorq
Kingman AZ
The coil doesn't care what wires you have, it'll work. If your old coil is tired and has too much resistance or something then you'll notice a difference.
95escahoe
95escahoe
thanks for the help, I have 240k miles and change and have no clue when it was last replaced so gonna go ahead and do it
AtomicHoe094
Atomichoe094
cleveland, OH
its like 40 bucks for the msd coil. its cheap and "supposedly" you get better gas mileage since it burns a hotter spark.. idk. lol
also about your PM, i have a 6a box with the harness i was actually going to throw up for sale last nite, but i forgot my camera at work to take pictures. Ill give you first dibs on it. 6a box, nice and clean with the wiring harness all done and wired up 125shipped.
I like it, i havent had it really on the "road" yet, but it works for me
99Yuk
Northern Ontario, Canada
Awww crap. This morning, I was thinking about canceling my digital 6AL order because it's on backorder, and talking to you about buying yours so I could get a move on it... haha....oh well, if 95escahoe says no, I'll bite....
BTW, 95escahoe. That's a good deal. I've spent the last two days looking at my coil and IGN module, and I've determined that the MSD Blaster SS coil that I bought is not a factory fit. Which means lots of custom wiring for me or buying the harness. Atomic is offering everything for less than 1/2 price new (CDN $ anyways). If you say no, then I'll buy it. hahaha....
---------- Post added at 10:23 PM ---------- Previous post was at 10:22 PM ----------
Didn't I read somewhere that the MSD coil and IGN boxes need helical wound wires? I can't remember where I saw that. IDK.
AtomicHoe094
Atomichoe094
cleveland, OH
haha thanks 99yuk
The msd coils for the 95 TBI motors basically bolt right in.. You need to take the OEM coil out of its bracket and use the bolts to put the msd back in the bracket. Supposedly a long time ago, MSD used to sell the coils already in that bracket, but like everything now a days.. Cheaper is the new Go-green..
retorq
Kingman AZ
... I've determined that the MSD Blaster SS coil that I bought is not a factory fit. Which means lots of custom wiring for me or buying the harness.
When I did the Vortec top end swap the coil mounting position interfered with the fuel lines so I mounted it on the firewall ... pretty sweet if I do say so myself.
99Yuk
Yup, your right. I just checked to see where I was reading about helical wires. It's the 6AL boxes that need them, not the coil.
95escahoe
95escahoe
ya thats the thing that got me I get like a 10% discount and the ad delco one was 60 or so and and msd was like 44 bucks so I was like if im gonna go all msd eventually why not get it, and I sent you a PM about that box
---------- Post added at 12:26 PM ---------- Previous post was at 12:24 PM ----------
I sent a PM so it prolly is gonna be gone and ya its deff a good deal cause new that box is like 200 and the harness is 35 or so and its in mint shape so why not do the upgrade lol
hyteck9
Columbus Ohio
Hello there!
I'm new. just bought a '96 Tahoe. *loves*
I'm giving it a tune up and did plugs/wires already.
I also bought an MSD Blaster coil to put on. I haven't gotten that finished yet. I began the sugery then got rained out... but honestly I'm not sure HOW to get the old one off? I had taken off the 2 flange nuts behind it and that seemed to accomplish nothing at all. LOL... didn't even wiggle a little.
I was searching the forum for some pics or how to's and this post is what I found. I won't be able to get under the hood for another week or so, but maybe you all can help me "think" my way threw it a little?
Is the coil bracket the skinny one that bends up-around the distributor and plug wires towards the firewall OR is it the more massive looking "plate" that seems to cover the back half of the engine?
Any help would be great. Thank you.
stuntmanray385
Hello there!
i did this myself not too long ago. entire msd set up on 96 2 door. to get the stock coil off you have to either grind off the metal pieces or use a hammer and flathead screwdriver. i used a hammer and flat head screw driver and it worked fine. the msd coil should come with screws and a nut to bolt up the new coil. heres a pic of my set up!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Hello there!
:welcome: There should be a third fastener holding down the bracket and you will have the undo the big wire harness clips as well.
95escahoe
95escahoe
I ended up getting the MSD coil and see how u gotta drill out the rivets to get the old one out and bolt the new one in, so im looking at it and it looks to be easier to un-bolt the bracket the coil is in take it out and drill it out and install the new coil then bolt it back in, but I can't get to the bolt to loosen it up, theres a metal line in the way maybe a fuel line? and a couple other things in the way, is there an easy way to get the bracket out or not? and this is for a 95 too
SunlitComet
OBS Jedi-Do Good
Your Vehicle: 1995 Chevy Truck Tahoe 4WD V8-350 5.7L VIN K TBI
Vehicle » Powertrain Management » Ignition System » Ignition Coil » Service and Repair
Notes Service and Repair
42407355
Coil Replacement
REMOVE OR DISCONNECT
Make sure the ignition switch is "OFF."
  1. Wiring connectors at the side of the ignition coil.
  2. Coil wire.
  3. Nut and bolt holding the coil bracket and coil to the engine intake manifold.
  4. Coil bracket and coil.
    • Drill and punch out two rivets holding the coil to the bracket.
  1. Ignition coil from the bracket.
INSTALL OR CONNECT
A replacement ignition coil kit comes with two screws to attach the coil to the bracket.
  1. Coil to the bracket with two screws.
  2. Coil bracket to the engine manifold with a bolt and nut. Tighten Bolt to 23 Nm (17 lbs. ft.). Nut to 33 Nm (24 lbs. ft.).
  3. Coil wire.
  4. Wiring connectors.
  5. Engine Cover.
AtomicHoe094
Atomichoe094
cleveland, OH
yea take out the whole bracket, grind and pound out the rivets or drill, then use the supplied bolts to hold the new coil in place. i wouldnt try drilling on top of your motor.
95escahoe
95escahoe
42407355
Coil Replacement
  2. Coil wire.
INSTALL OR CONNECT
  3. Coil wire.
  5. Engine Cover.
thanks for the info
---------- Post added at 11:24 PM ---------- Previous post was at 11:22 PM ----------
ya thats what im gonna do just gotta figure out a way to get that bolt out to remove the bracket cause u can only reach one rivet and dont wanna risk hitting anything
95escahoe
95escahoe
ended up putting it on last night, it idles better and starts better guess mine was shot if anyone is looking for a coil I highly recommend the MSD one.
haks310
Got LEDs?
SoCal
**** that MSD coil! Mine crapped out after 14 months
How you liking those Hankooks by the way? P or LT metric?
95escahoe
95escahoe
The Hankooks are great haven't had any problems with them, had a pretty bad winter up here never got stuck, there good in the rain, been off-road nothing crazy and they were good, and they don't make alotta noise on the highway if your looking for a A/T tire I would highly recommend them and the tires are P I think cause thats in the number on the side
mfinta
