How to remove the dots above the cutoff on Depo headlghts
Kman
Southern California
As many of you may know, the Depo headlights have three pin size holes in the cutoff shield on each headlight. This is supposed to light up signs, etc. but when driving around it gets annoying.
Here is a picture of the dots above the cutoff on Depo headlights:
Here is what I did to remove the dots.
1) Cut the ends off two Q-tips to remove the cotton. Tape them together so it's long enough to reach into the projector to touch the cutoff shield:
2) Locate the three pin holes in the cutoff shield:
3) Mix JB Kwik Weld. This sets in 4 minutes instead of 16 hours like normal JB Weld.
4) Roll the Q-tip's end you taped together in the freshly mixed JB weld. You need to work quickly because it sets fast. Reach in very carefully and cover each of the holes. Set the headlight to the side and do the other headlight.
5) Let sit for 3 hours before you put the bulbs back in. After 3 hours install the bulbs and re-install your Depo headlights.
6) Enjoy your hard work. No more dots above the cutoff:
waxworkz
are you using depo headlights with hid bulbs? i like that cut off. i am going to need some new headlights soon, i was re-polishing and re-clearing them this weekend and noticed one has stone cracks in it. i have the clear depos but i have hids and want the projector effect
Kman
Kman
Southern California
Yes, I am running a DDM 55w with 5k bulbs.
Physh1
Hmmm...mine didn't have that either. Interesting...how long ago did you buy your Depo projectors?
DenaliAK
Colder than you
Alaska
Nice fix. JB Weld to the rescue!
My question is why the hell are there holes in the shield to begin with? That doesn't make any sense at all.
Escalade2007
