How to remove headlights?
tahoe26
Hey guys, im trying to install my hids for my 07 tahoe...A friend of mine told me i have to remove the front bumper to access it? Is this true? Thanks for any imput.
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
From what I've heard the Yukon's and Tahoe's are the same for this mod... I removed the bolts that are holding the housing in place on top, and also removed the grille's center mounting bolts(to allow for additional room when removing the housings). I then removed the inner fenderwell front bolts and/or fasteners to allow access to the headlight housing's lower bolt. Once these were all out the housing was carefully removed using care to prevent chipping the paint. Mine have to be popped out of their snapped in, seated position. Once this is taken care of I can remove the housing by rotating it in a circular motion from the inner lower corner outward (clockwise on driver side, counter-clockwise on passenger side).
Personally, I left the lower bolt out to facilitate future removals... eliminating this step.
yolo
MarkBarbee.com
Phoenix, AZ
so i have to take my inner fender out to remove my headlights? does anyone have a step by step to remove the head lights?
T
tahoe26
Thanks, ill try that when they come in! Alot easier than removing the bumper
yolo
MarkBarbee.com
Phoenix, AZ
looks very time consuming. why couldnt the NBS lights come out like the classic body style? ERRRRRRR!:emotions122:
Modded
That Guy
I have a write up about this in the Tech section....
Yukon Ron
Texas
Thanks for the link on the removal, definitely not quick release like my 01 Yukon. This is the first negative I have found in my wifes new tahoe.
CHOO CHOO
BackPagePhil
Manheim, Pa
I just replaced my bulbs last sunday and it wasn't as bad as I thought. Modded's how-to is a big help. Its just more of an annoyance than anything. I just needed a #10 and #7 socket and was good. Good luck man!
yerpderp
What about the two bulbs on the bottom of the assembly? Daytime driving and the amber bulb beside it. Anyone have wiring issues with these? Sorry...I used this thread to access these bulbs. Changed them and the driver side daytime light still isn't working. Passenger amber bulb isn't either.
2009 Tahoe (xfe)
fatboyracing
All you need is a 7mm and 10mm socket and ratchet as well as a panel popper tool
Remove the 2 bolts and 3 push in clips on each side of the fender well
remove the 6 bolts on the top side of the grill
unhook fog light wires
unbolt 2 bolts on the bottom of the bumper one on drivers side one on pass side
After that pull each at the fender well away from the truck (not towards the front but out)
once each corner is out pull the hole thing forward
vsaravia
