How can i run 33's
maddawg
i need some part numbers guys. My hoe has 4x4 it's not a z71 but i more than likely will end up off road. Lets just say i like to test my vehicles i mean just in case the zombies come lol. Seriously i'm probably gonna go with a 22" wheel but i want to be able to run the biggest tire i can. I may even stick with 20" and even meatier tires
My last rig
Blazed
Accepting Donations
2.5/1 ccm leveling kit for 129$ will have you able to run 33"
maddawg
maddawg
Now here is a stupid question whats 33" in XX/XX/22 format lol
Blazed
Accepting Donations
Well toyo makes a 33"x12.5"/22"
---------- Post added at 08:38 PM ---------- Previous post was at 08:37 PM ----------
That's what I would go with but
---------- Post added at 08:39 PM ---------- Previous post was at 08:38 PM ----------
305/45/22 would be a 32.8" tire.
---------- Post added at 08:42 PM ---------- Previous post was at 08:39 PM ----------
12.5" is 317.5mm in width
Gzes
the drifting 2dr
Wichita tx
Yep depends on tire really but you migt be able to run 33s on stock with a lil trimming
Zed 71
Pacific NW
You will need to trim 2 inches from the front valence caps.
yates ™
Resident Apple hater
Iowa
What wheels are you wanting to run? The offset will determine have a lot to do what you need to do.
maddawg
maddawg
I'm running Ultra Goliaths 9.5 wide +30 offset. I'm getting them on tomorrow with 305/40/22 cooper LTZ tires. I may try to bump it up after the summer months. CCM 2.5/1 lift. and some 305/50/22 toyos
felixgun
Lafayette, LA
I'm running the Toyo OC MT 33x12.50R22 tires on a 2.5/1.5 leveling kit and it rubs on the wheel well liners up front. I only slightly rub going up incline driveways now after trimming.
james035
Can anyone point me in the right direction to find an actual pic of the trimming done for a ccm leveling kit a and 33's?
Zed 71
Pacific NW
The attached shows trimming I did (the red lines) to fit 33s with CCM kit. This was about 2 inches. I think the original pic was from someone trying to fit larger width tires (305s?), but at that size they also needed to remove the side steps.
felixgun
Lafayette, LA
James every car is gonna be slightly different. Just turn your wheel and see where it hits the wheel well. When it hits. Stop and get out of the car and look exactly where it's hitting. Go back in the car and turn the wheel back straight and cut around that area. That's all I did and I'm fine now. I'm running a leveling kit and 33's...
Zed 71
Pacific NW
Also if you take if off-road, you need to take into account suspension flex. This will become apparent when you hear the wheel liners "complain" while playing in the dirt :doh2:.
Conedaddy
