Hidden Fog Lights!
danimalmax
louisiana
Check out this mod my brother and I just did to his z71:
when the weather clears up i think i'll go and do the same to mine
Tribalbreak
WARminster PA
i like it... any way you could put some pics of how you mounted it and what all is involoved? i have a denali that i had considered hiding fogs behind the grille but havent done it yet....
danimalmax
danimalmax
louisiana
sure, we have it open right now because we're putting those wire cover things over all the wires, i'll take some pics of the brackets
danimalmax
danimalmax
louisiana
here you go tribal:
all i did was get some aluminum tubing and cut it out so it only had 2 sides, a back and a bottom, then used self tapping screws to screw it onto the frame that you see in the pic, then i drilled a hole on the bottom of it to mount the actual light onto, except i shaved the bracket thing that came on the bottom of the light so it would sit flat and sturdy onto the metal, then the ground is on the bottom of the bracket under the same bolt
SFBerto415
California
Looks sweet. Do they come on with the stock fog lights or did you have to install a secondary switch for them?
HMFDZ28
Hunt Sta, NY
Pretty cool... That kinda what we do for LED or Stobe lighting in a grill of a Burb or Hoe. Diggin it!
danimalmax
danimalmax
louisiana
my brother decided to mount a switch for his lights under his dashboard, but when i do mine, i think tomorrow, i'm gunna try to rig it up to come on with the rest of my brights so that it will become a 10 high mod - not sure how im gunna do that though
police cars?
UWMlax15
Connecticut, Wisconsin
dammit! I thought I was the only one with those. I've got it on my '96 though, so I may be the only one with them with the obs. They turned out really nicely though, good job. Props on the fabricated mounts.
Man Van
Texas
Very cool. Would make for a great show mod. Howabout wiring it to the onstar button? Is that possible or would you have to use a seperate switch?
danimalmax
danimalmax
louisiana
onstar button? i dont have that in my car but my brother does, we will soon be making a 4-5 switch board that goes in place where his cassette player used to be, its going to be a pretty easy mod, all i need is a sheet of plastic to drill 4 or 5 holes in and glue it on the backside of that cassette player hole
---------- Post added at 06:25 PM ---------- Previous post was at 06:21 PM ----------
just did mine today:
Tribalbreak
WARminster PA
d-max thanks for the pics and the write up... i want to rig something up but i wonder how it would look behind the nali grille?
moto
