Hid for 2002 denali
jada
what is the best hid kits, i have a 2002 denali xl what to do low and fogs, should i go with 35w or 55w. read some post on ddmi and little confused on lumens some say stay between 3500 thru 4500 please help ready to order
ezdaar
Chat Troll
Redneck central, Aka Houston
If you want the best, here they are.
These kits while only 35watt, will actually produce more light than a 55watt DDM and Other low end retailers kits.
Morimoto Stage II HID Kit: D2S $155.00
These are DS2 Bulbs and WILL NOT work in our 9005/6 housings. as they sit Stock.
I found a adapter plate awhile back to allow them to work, but cannot find it now.
Most of our bulb sockets have a screw on locking plate that determines the bulb type that will actually fit and lock in. As stated, there is a plate out there to convert denali projectors over to DS2.
This kit however, will drop right in, simply select the correct type from the drop downs and your good.
Morimoto Stage II HID Kit: AMP $150.00
This is a Complete kit, Bulbs, ballasts and Relay harnes.
Do this with DDM or any other low end kit and watch it blow up
http://www.youtube.com/watch?v=hVuIba2kZ9I
rossida
