HID Fog Problem
puckhead
CO
So I just did the 6 hi mod yesterday by adding a diode from the lows to the fogs relay. Already had the lows grounded out.
When I turn my lights on today all the lights flicker and two go out. Tried it several times and different ones go out. Real bad flicker. So I pulled the diode and everything is good to go. Did I do something wrong? I used an "Epoxy Rectifier Diode, 3 Amps 200PIV". Did I use the wrong one?
Is there a better way to do this? Does grounding out the fogs work like grounding the lows do? Thanks guys.
puckhead
puckhead
CO
I think I am just going to re wire it on its own separate system. That way I can turn them on whenever I want. For the fog wiring, I assume it goes all the way back up to the fuse box and is the same color wiring as at the actual light housing?
puckhead
puckhead
CO
lol.
Thanks though! And yeah the metal prong is touching.
I will just have to play with it and see if I can get something to work.
gdddup
NJ
do you have a volt meter? see what kind of power you got at the harness. you might need to wire in relays for the hids. im not too sure about the diode thing
puckhead
puckhead
CO
Yeah I didnt think about that. I do have a meter. I will have to check it out. Is the relay you are talking about just the regular automotive relay? Or are you talking about an HID harness?
chauncey0337
MLT, WA
If everything worked properly before the 6 hi sounds like the diode is messing things up. I'm not sure what kind of diode to use but make sure you have the correct one. Also, like gdddup said, if you don't have a relay harness already, it's a good idea to get one for each pair of hids. The relays will supply the ballasts with the correct voltage needed directly from the battery.
polobuds
East Bay, CA
No need to do any of that grounding, at least I didnt have to do that. Took me all of 5 minutes (with most of the time trying to get the damn relays out of the socket!) i think you want the 3amp, 50 volt diode (radio shack ones for $1.75). Make sure the grey part of the diode is pointing towards the high relay. I just did the 4 hi mod, and for the hell of it, did the 6 hi mod to see if i liked it. had it for a day and decided i didnt want the 6 hi because i have HIDs in the fogs and didnt want to turn them off and on all the time with the highs. Although i may connect fogs to lows.
pics always help...
pic of my 4 hi mod. diode in #85 spot from low relay to #85 in hi relay.
if you wanted to connect fogs to low relay (HDLP - Low), connect diode from #85 fog relay to #85 low relay (follow arrow). You'll have two diodes for the low relay, but take your time and you'll be able to fit it in there. If you wanted to do 6 hi, instead of connect diode from fog to low, connect diode from #85 fog to #85 hi relay (HDLP - High)
puckhead
puckhead
CO
Thanks for the info bud! Mine is set up a bit different though. Gonna double check the diode though.
Rivieraracing
Sorry, this is the first time I noticed the thread!! Did the HID fogs work before the diode? If so, I'd say it's the diode, if not, then I'd say you might need a harness!
puckhead
puckhead
CO
Its all good dude, thanks for taking a look!
Yeah since I pulled the diode everything is working great. No flickering in the lows or the fogs at all. Nice smooth warm up every time. I might run to radio shack real quick and make sure I didnt pick up the wrong diode. Thats the only thing I can think of unless there is some strange wiring bug in my electrical system.
sierraman
Paris, Texas
Thanks for the link! Not a bad price either. I wonder how their system is set up.
you have 3 t-taps, and 1 eyelet, all wired into 2 relays. you tap into the highs, low, fogs and use the eyelet on your ground. when the high beams are switched on, they send signals to the relays to turn on the lows and fogs. very simple install.
puckhead
puckhead
CO
Interesting. Thanks! This would probably save a lot of people on here a ton of time, money, and frustration lol
Drewphil
