So I just did the 6 hi mod yesterday by adding a diode from the lows to the fogs relay. Already had the lows grounded out.
When I turn my lights on today all the lights flicker and two go out. Tried it several times and different ones go out. Real bad flicker. So I pulled the diode and everything is good to go. Did I do something wrong? I used an "Epoxy Rectifier Diode, 3 Amps 200PIV". Did I use the wrong one?
Is there a better way to do this? Does grounding out the fogs work like grounding the lows do? Thanks guys.
