Jason in DLH
Cheeseburger and Fries
Figured this might help someone in the future and I’m curious to see how others are setup, so please let’s see how you did it!
In my custom audio build I first started with the subs that I wanted that fit perfectly in the back:
2 -10” Kicker CompC 4 OHM 300Watts RMS Each
I then decided on the amp (I simply took a Sawzall to the piece of carpet that detaches from under the 2nd row seats). I removed the driver side 2nd row to run the RCA, Remote Turn On, and Wired Amp Control underneath carpet and up to the dash. I brought the power cable (inside wire loom) at about a 45 degree from the battery inside the wheel well and attached it to the frame and brought it up through a grommet I installed (under front passenger side sill plate). I then caulked the grommet from the inside and outside. I stripped the paint near the amp for the ground wire and sealed that with rubberized coating.
Alpine MRV500 500Wx1
Finally I chose the head unit. A Kenwood DDX376BT that was easy to bypass parking sensor so you can watch videos while on the go.
Kenwood DDX376BT
And the final touches...
The wired Amp control and microphone for the hands free calling and what not (I always wondered what that little empty box was for. Now I know...a microphone!)
Overall I’m satisfied with how it all turned out. I especially like the wired amp remote so I can turn the bass down. Oh, I needed to remove the rear lift trim and caulk/tape all the loose wires and connections as the rattling was unbearable. I also caulked the license plate bracket. It still rattles, but not nearly as bad.
I think my next build will be 2-15” Solo Barics and I’ll build my own ported box.
Kenwood DDX376BT
