Help with front brakes!
Brom48
I’m having a hard time find the right parts for the PPV brakes up front! Is there anything specifically different than the other tahoes?
Part numbers or anything would help
Brom48
Brom48
The pads have a slightly different composition. Otherwise they are physically identical to consumer brakes. You could go into any corner parts store and get pads if you needed to.
if you want PPV pads specifically, Rock Auto should have them.
And are the rotors any different?
ACDelco Professional specifies an enhanced performance rotor for Police, 18A1705PV/19310735.
They also offer loaded calipers for Police - Right - 18R2659PV/19322766 and Left - 18R2660PV/19322767
Enhanced Performance Police Semi-Metallic Pads - 17D1367SDH/19366010
I did my front brakes for the 3rd time at 135K and by 150K or so a piston got stuck in a caliper and had to do the fronts all over again with new calipers this time.
scottd
