2000tahoeZ71
- Joined
- Jan 13, 2014
- Posts
- 236
- Reaction score
- 2
I have about reach the breaking point trying to figure out where my coolant is going. I have replaced intake gaskets, water pump, upper/lower hoses, radiator, radiator cap, intake fitting, all heater hoses, and heater core. It's not going in my oil. No obvious external leaks. No coolant smell after its hot. Getting a little bit of condensation on startup, but doesn't smell like coolant at all. Pressure checked it hot and cold, builds and holds pressure. All spark plugs look normal. I can fill reservoir and after a couple hundred miles it will be gone and radiator down to where I can see the top of the fins. The only thing I haven't changed is the overflow hose and reservoir, but like I said I'm not smelling anything from the engine bay or seeing any leaks at all. Any ideas?
